Brake bleeding question
on
I am planning to do a brake upgrade, but I am somewhat concerned about bleeding the system after reading an answer to a brake bleeding question in GoMini. The mag stated bleeding a system with DSC is more complicated and requires the engine to be running and the use of BMW/MINI dealer's Modic' computer system. Any one know any thing about this?
thanks,
thanks,
Originally Posted by jimz68
After installing steel braided hoses, we bled the system with Ate Super Blue fluid. Used the ol' fashion pump and holdem method and it worked just fine.
Jim
Jim
Originally Posted by apexer
I also did the clutch as it uses the brake resavore.
This weekend I plan to install stainless steel lines and put in ATE Super Blue, I just want to make sure that the new/fresh fluid makes it into the clutch part of the brake system. :smile:
Originally Posted by paddy
I understand that the clutch uses brake fluid, well not really but that is a discussion for another time. Where is the bleeder valve for the clutch??? Do you follow the same procedure as with the brakes, pump & holdem....
I did the clutch last on the first bleed rotation (r/r, l/r, r/f, l/f, clutch). On the second bleed rotation, I didn't bleed the clutch at all.
durablack
R55 :: Clubman Talk (2008+)
10-05-2015 01:51 PM
thebordella
08-31-2015 01:37 PM
