Changing front brake rotors and pads on R53
Labor rates vary a lot, dealership rates are super high.
Labor for front brake pads and rotors is about $100-250.
$100 labor if they are selling you the pads and rotors with a marked up price.
$200 labor if you supply the parts which is usually the best way to go.
Pads that will suit your priority/needs- street use, not noisy, low dust.
Rotors- basic plain rotors with a painted hat to resist corrosion.
Dealers love this because any mechanic usually can beat the flat rate by half and sometimes more. For instance I am not a working mechanic but can do both sides of my 2003 MCS in an hour with pads and rotors. Not rushing. Of course on your car the rotor hold down may be stripped and that will double the time and that gets figured into the flat rate but I think you get the idea.
I have no access to the Flat Rate books but I would assume it would be at least .75 a side and possibly an hour a wheel flat rate. OTOH, pads and rotors are the easiest job for us to do ourselves. It does take a good set of ratchets and a brake tool for the rear caliper, but I believe that anyone who owns a car should have a basic set of tools as well.
///Rich
If you think you have the tools and have to figure things out as well, double the time.
///Rich
07-16-2020 01:54 PM
squawSkiBum
10-02-2015 10:21 AM
