HERES THE PICS 8in in front and 9in in rear
Old 07-04-2004, 03:09 PM
KiLO's Avatar
KiLO
KiLO is offline
DiD, I got the same message...
  #27
Old 07-04-2004, 03:54 PM
bodinski's Avatar
bodinski
bodinski is offline
Is the stock offset not 50 (as opposed to 38)?
  #28
Old 07-05-2004, 06:39 PM
d6-mcs's Avatar
d6-mcs
d6-mcs is offline
i am running way 5 to 10mm offset difference then stock.
  #29
Old 07-05-2004, 09:20 PM
kenchan's Avatar
kenchan
kenchan is offline
Stock MCS offset is 48-50mm on all corners on a 7inch width wheel using
205 tires...(17x7)....
How much tramlining are you getting right now? any torque steer?
Originally Posted by d6-mcs
i am sure that the wheel bearing will last, i am not using any spacers at all. and the stock offset is 38 and i am running 35mm offset in front and a 25 offset in rear, so in a way i am only stressing my rear bearing by 10mm of more offset then stock. my wheels bolt up straight on the hub so pretty much not doing anything different then a standard set of wheels. if i was running spacers then it probably would stress the bearings but i am not. as for the kw's i hope that i dont get into that situation of the tire rubbing, but i am running wheels that are 10 to 20mm offset less then your so i dont think i am going to have any problems with that, only my fender flares.
chris
  #30
Old 07-06-2004, 06:23 PM
goin440's Avatar
goin440
goin440 is offline
Originally Posted by Bisch
Hey, look. Another MINI with stretched tires!
^^^Anyone else think this setup looks thin in the tire?
D6... Setup looks real good.
Also, bearings may go quicker than with stock. But after a 100k, who cares.
  #31
Old 07-10-2004, 07:30 AM
mcs22004's Avatar
mcs22004
mcs22004 is offline
245 worth exploring for 9" wheel?
Originally Posted by Alex@tirerack
245's are pretty agressive on a mini, lowered or otherwise.
Alex
I'm not too keen on the style of wheels in this topic, nor do I like the stretched look, but it seems that 245/35 x 17 would have a total height similar to the 215/45 Blizzaks I ran during the winter. The issues would be rub and offset.
What are the max tire widths that can be fit inside the front and rear wheel wells and at what offsets?
07-16-2020 12:54 PM
W0TM8
12-19-2019 07:50 AM
emulajavi
12-24-2018 09:15 AM
FLYM1N1
08-15-2015 11:20 AM
Minibeagle
08-13-2015 10:00 AM
Quick Reply: HERES THE PICS 8in in front and 9in in rear
