Load Rating of Wheels?
I know tires have load ratings (84 = 500kg or 1100 lbs is the
minimum for an MC or MCS), but my wheels have load ratings
embossed on the rim for the various bolt patterns available.
I have SSR GT1's in 16x7 --- around the rim there's: 4x100 - 500kg;
5x100 - 505kg; 4x114.3 -620kg; and VIA - 690 kg.
don't recall seeing a load rating on any other wheels lately, not
even hiding on the back.
Actually, since the SSR's are semi-solid forged, I thought they'd
be rated a bit higher than 500kg for the 4x100 wheel bolt pattern.
Are the SSR comp's rating (about 3 lbs lighter per wheel) the same or
different? Any other brands list this? Perhaps Alex has some info.
By the way, I love these wheels, and have had no problems with strength
in over a year of spirited driving on less than ideal roads.:smile:
Strange rim load rating numbers
The rims also have a load rating and the GT1 has it clearly marked. A few other rims may have this too but not many do. Obviously it would not be a maximum load rating of 500kg for this rim which is quite strong.
Try calling/emailing Alex@tirerack and ask him for the lowdown on these interesting markings and then please do post the answer so we can understand why SSR took the time to forge the rims with those numbers.
I am doing some double checking on SSR data.
Typically wheels in a given bolt cirle are targeted to application -
the less lugs and the closer the spread the less heavy the target vehicle is. (Think of 1 ton trucks - more lugs bigger circle)
In this care SSR uses SSF to reduce mass, while maintaining strenth.
If the SSR weighed 25 lbs like and S light, it in theory would get a higher rating.
Balance that with reality of application to target vechles load requirements -
Hence a Civic doesn't need more than 1100 lbs a wheel - so lets make his wheel lighter, and help him overcome horsepower restrictions.
Alex
Alex
Alex
Alex
I'll edit this:
to read-
In this case SSR uses SSF (semi-solid forged method of wheel manufacturing) to reduce mass, while maintaining strength.
I'm noticing those numbers are on other SSR rims as well.
In the world of the design engineer, EVERYTHING has a load rating that is subject to any kind of load....and everything is subject to loads.......in vehicles, tires, wheels, bearings, seals, axle stubs, suspension pieces, suspension bushes, suspension bolts, suspension nuts....ad infinitum........
07-16-2020 12:54 PM
Powershift
08-16-2015 05:14 PM
08-12-2015 01:24 PM
