New Rota's Going On Soon. Couple of Questions.
I really like the old school Rota look so I will be purchasing a set of RB's from Aspec. My Clubman is new with only 1,700 miles on it. I can't justify new tires at this time so these will be mounted on stock 195/55/16 run flats. Current wheels are Mini Rib Spoke which are 6.5" wide. The Rota's are 7" wide. Will these fit my tires? Any issues with TPMS? Should be a straight forward switch out right? These are the wheels:
Found this thread from way back. Looks like they will fit with no problem.
https://www.northamericanmotoring.co...rota-rb-s.html
New non runflat tires do not have to be expensive considering the cost of mounting and balancing runflats.
see
http://www.tirerack.com/tires/survey...=true&filter=y
About $90 or less per tire in Ultra High Performance All Season, more choices in 205/50-16 and 205/55-16.
You can either sell the runflats with the OEM wheels as a set and skip the dismounting of the tires or part out the wheels from the tires unless you are keeping the wheels for winter use.
atlantaorange
09-16-2015 12:43 PM
