215/60r17 snow tires 2015 countryman
Old 01-06-2015 | 03:39 PM
Coopercountry's Avatar
Coopercountry
Does anyone know or is anyone currently running these size tires on their countryman 215/60r17. I can get a good deal on 4 but only want to grab them if they will fit.
Old 01-07-2015 | 12:45 PM
MyroMini's Avatar
MyroMini
I'm running 215/55R17 Nokian Hakka7 on my JCW and no issue
Old 01-07-2015 | 03:05 PM
Coopercountry
Thank you!!! This is awesome news I am going to go and get these tires tonight. I will probably get them installed this weekend. Let ya know how everything turns out. How do they look and ride on your JCW???
Old 01-08-2015 | 09:15 AM
Alex@tirerack's Avatar
Alex@tirerack
Just to confirm your tire size is almost 1" taller than Myro's.
Old 01-08-2015 | 10:33 AM
Coopercountry
I know, at first I didn't realize that Myro was running 55's. Do you know if the 215/60's will fit a 2015 countryman on the stock 17in wheels?
Old 01-08-2015 | 02:09 PM
bmwr606's Avatar
bmwr606
i am running 205/70R16 winters on mini oem euro alloy 16x6.5 et 46 wheels on my all4
the tires have an od of 27.3 inchs and i have the factory sport suspension, 10 mm lower than the standard suspension
no rubbing or other clearance issues
Old 01-09-2015 | 01:45 PM
Alex@tirerack
The tires have an od of 27.3 inchs .....no rubbing or other clearance issues
Great to know, Your 215/70's are only 27.1".
@ bmwr606, do you think you could accommodate the 1/4" more width on each side?
I am checking with my tech team on this one as well.
Old 01-09-2015 | 02:42 PM
Alex@tirerack
@ Coopercountry
Is yours an all4 ?
Old 01-09-2015 | 03:22 PM
Coopercountry
Yes it's an ALL4
Old 01-09-2015 | 03:42 PM
bmwr606's Avatar
bmwr606
yes, i have at least 1/4 inch clearance
my wheels are 16x6.5 et 46 ...
my CM ia an all4 with factory sport suspension
Alex, i bought the tires from you ... dunlop grandtrek sj6
Old 01-12-2015 | 02:19 PM
Alex@tirerack
Looks like clearance is pretty close when turning lock to lock. We get as close as 18mm. Not much room for packed snow or ice.
Old 01-13-2015 | 01:29 AM
bmwr606's Avatar
bmwr606
205/75R16 front tires rubbed at less than full lock with 4 - 200 pound plus guys sitting in the car ... car was sitting on the front bump stops
the rears rubbed when 2 more 200 pound plus guys sat in the open boot .. car was sitting on the rear bump stops
no rubbing under the same conditions with the 205/70R16 tires
i have not had a problem with packed snow/ice limiting steering with the 205/70R16s
Kimolaoha
12-05-2020 10:32 PM
woodstudio
03-15-2020 09:28 AM
kazyn
10-25-2019 03:34 PM
peicraig
Canada
08-22-2015 08:48 PM
col127
08-21-2015 03:11 PM
Quick Reply: 215/60r17 snow tires 2015 countryman
