clearance question - Avid 15x8 wheels and r53 calipers
on
With stock suspension you may have a problem getting the right tire to fit the wheel wideness and be tall enough to fill out the wheel gap.
It may be possible to use a more narrow tire that has a tall sidewall for a stretched fit.
on
Which Street class are you referring to? Check limits of wheel width and tire width if in Street Touring classes, also treadwear limit of 200.
If for D Street class you can run 18x7, 17x7, 16x6.5,or 15x5.5. offset within 7mm of OEM.
see
http://scca.cdn.racersites.com/prod/...ok_online1.pdf
Wheel diameter can be increased or decreased 1" from the OEM part for that model.
In STX, wheels can be up to 9" wide, 265mm limit on tire width.
on
Running in BMWCCA National Capital Chapter.
http://forum.nccbmwcca.org/content.php?138-Classes
tuner class allows free wheel and tire size choices above 140 wear rating.
07-16-2020 12:54 PM
squawSkiBum
10-02-2015 09:21 AM
sabjcw
08-14-2015 07:40 AM
