Minus Two
Minus Two
Tires mods usually take the form of Plus one or Plus Two upgrades. I went the other way. I replaced my stock 17" SLites w/ runflats w/ a set of 15" SSR w/ 205-55-15 toyo proxes T1S. If the stock wheel/tires weigh around 50lbs the new SSR combo is only 27lbs. I reduced the 23lbs per corner. What an improvement in acceleration. The car redlines so much faster. You step on the gas and the car jumps. This is my first mod and I wanted to do something that will improve performance, hadling and braking. How much horsepower is gained by reducing the unsprung weight?
Originally Posted by polmear
the reduction in weight is not what is giving you the gains, it is the reduction in radius. there is a smaller moment in the smaller tires, that gives you a bigger 'jerk' than your old 17"'s (the change in moment over the change in time: dj/dt for those real physics nuts) the smaller tires allow you to use more of the torque, more quickly-thus better acceleration, better braking (as long as the tires don't slip)
I weighed the Xlites with the runflat tires at 40lbs and the Rota's with Azenis at 34lbs. HUGE Difference!
Second, NO horsepower is "gained" by reducing the wheel weight. You keep the horsepower that you had before but you improve the power to weight ratio in a very meaningful way. You shift to smaller diameter wheels which helps gearing and loose a lot of unsprung weight.
More related threads-
https://www.northamericanmotoring.co...lighter+wheels
and
For street driving I have aftermarket 17x7" rims and non runflat tires for 38 pounds each compared to stock S-lytes and runflats for 48 pounds each.
For autocross I use 15x5.5" stock holeys and Kumho victoracer 205/50-15 tires at 30 pounds each. It makes a very big difference to loose that much weight. Speedo is affected though.
somedays it just don't pay to read what you said...
if you ignore the my first sentence in my previous post, or substitute:"it is the combination of a reduced radius and reduced weight that gives you a smaller moment" my post will then make a little more sense.not a whole lot more, just a little
Your right. The car still has the same hp with the new wheels. I wonder if wheel horsepower will be the same if you compare the stock wheels w/ the SSRs 15". I have not seen any thread with the dyno comparison of different wheelsets. Dyno runs are usually done on bolt on parts.
VanisleRyan
26
09-15-2015 06:19 AM
kellymac
08-30-2015 10:11 PM
kyungmanpark
08-23-2015 07:26 PM
