Question regarding 215/45/R17 Wheels
#26
sent back.
You can separate them like the web spokes:
https://www.northamericanmotoring.co...el-thread.html
#27
Yep, one of few 2 piece wheels from MINI.
#28
OK, so I got the tires replaced. I ended up getting Yokohama S-Drives. They feel a lot better than the run flats.
There's definitely more grip now, not just when turning, but also when you hit the gas. Now when I turn, I don't feel like I'm going to roll over.
TPMS is working now. Only took a few minutes to reset.
The only concern I have is that the tires feel a bit stiffy, but I think it's the inflation.
Mike, do you know the recommended PS I for 215/45/R17s?
#29
Looks nice , did you see the recommend PSI in the door jamb sticker for the wheels , or did someone get those R90's afterwards. Not stock with the car.
PSI chart for size : Follow the 17" on a R56 S requirement if you dont have the 17" on the sticker
https://www.northamericanmotoring.co...ntenintal.html
#30
Thanks for the link.
#31
Welcome. Some people like 32~33 in general but underinflated for the size and the chassis will cause cupping on the inside sometimes.
here some more info on the 215 crew
https://www.northamericanmotoring.co...5-45-17-a.html
#32
I'll check this new link. The guys at the shop did 40 PSI.
#33
#34
I've been recommended this kit, a bit pricey, but it looks quite awesome. Basically it does both jobs. Has any of you used it? https://www.ecstuning.com/Search/Sit...675/ES2714992/
offapex
02-01-2016 08:37 AM
