Question regarding 215/45/R17 Wheels
I've been asking around in different thread but I can't seem so get the answer so far, so I decided to start a new fresh thread with the same question.
Will I have any trouble switching from 205/45 R17 run flats to 215/45 R17 NON-RUN flats?
I'm running on stock wheels with no lowering (R56). Picture below in case it helps.
Any input will be appreciated. Thanks in advance.
Stock wheels with 205/45 R17 (run flats)
According to the tool, it should not be an issue space-wise.
Do you know if it has any effect on the speedometer and things like that?
You shouldn't have any issues. The 215s are only slightly wider than the 205s, but the same diameter (17"). The only time I've heard about the tires/rims affecting the speedo is if you change sizes, from 17" to 18", for example.
The change from run flats to non-run flats was one of the best choices I made.
According to that Miata tool provided by netma1000, it says:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/45-17 3.6in 12.1in 24.3in 76.2in 831 0.0%
215/45-17 3.8in 12.3in 24.6in 77.3in 819 1.5%
So it definitely must have some effect on the speedometer. The question is, how much of a difference.
Also I've been told the MPG is going to decrease a little bit.
I'm going to give this a try.
I am going to start with a set of Federal SS-595 EVO as they seem to fit the budget and have decent reviews.
Thanks.
It also seems that even though you're technically increasing the width, they always add at least .2 inches to the sidewall for whatever reason.
Also, went with the non-RFT. OMG, what a difference in ride, and the non-RFT is repairable if you pick up a nail. I thought about the last time I had a flat tire, it was decades ago. In any event, am too old now to be changing out a flat tire. I plan on using AAA if it ever happens..
I did exactly that last week. I moved up to the 215 from the 205 based on the advice of the Discount Tire guy. Almost all the 205 was special order, the 215 were all in stock. Seems the 215 is a more common size.
Sure, I'll post some close ups tomorrow when I take the Mini out. They fit the wheel well, I'd be surprised if you can see a difference between the 205 and 215. As another poster pointed out, the overall diameter is a tad taller, making a small difference in the accuracy of the speedo. Since the speedo already reads about 3 mph high, I think it actually makes it a bit more accurate. Am not a math major, so I could have that wrong.
Lots of good tires out there with threads here at NAM describing them. For what it's worth, this is what I went with -
http://www.discounttire.com/dtcs/fin...=AZRINT&cs=215
Thanks man. I was thinking of getting the MINI repair kit. I have AAA, but I know sometimes they take a very long time to show up.
Air pump + Slime is a great suggestion, esp. for road trips. Like many others I have AAA, but you never know how long they'll take or if you might/might not have cell reception so having a Plan B is just plain smart.
One thing that surprised me is that 215s can be cheaper than 205s. I priced a new set of Michelin Pilot Super Sports, and 205s are $22 more than 215s, per tire.
The difference between RF and non-RF tires is marked - what an improvement!
Basically it does both jobs. Has any of you used it?
https://www.ecstuning.com/Search/Sit...675/ES2714992/
Rare to see R90 wheels in anthracite on an R56 Cooper S , sport aero kit ( hypersport ) and non painted arches . I think we hit a rare combo there.
I actually bought it exactly the way it looks now and didn't change a thing except or the cowl and the wipers). I was looking to replace the wheels, but everybody keeps telling me I'm crazy and that they look great on it, so I'll do that when these are no longer good enough and I have the money to afford it.
I hope the new tires make it look a bit more sport-ish.
Welcome. Just keep them and you could also repaint them or refinish them.
sent back.
You can separate them like the web spokes:
https://www.northamericanmotoring.co...el-thread.html
