Need new summer tires
Old 04-30-2016 | 08:15 AM
TG.'s Avatar
TG.
So I'm giving the PSS a last chance...
Aside from tire rotation (which I'll plan on doing much more frequently), and the alignment I'm having check on Monday, what tire pressure should I be using with this type of tires: 205/45/17 Michelin PSS to reduce inside wear?
41psi or higher?
41 psi is what is recommended in the manual for the R59 S
  #27
Old 04-30-2016 | 10:17 AM
Richard Davis's Avatar
Richard Davis
Just a side note; when I went from 205-45/17 run flats to the Pilot Super Sports, it was recommended then I go to a 215-45/17. Better ride, no down side. So that is what I did. I won't be going back to 205's. Anyone have thoughts on this?
  #28
Old 04-30-2016 | 11:25 AM
hsautocrosser's Avatar
hsautocrosser
It is a commonly used size without reports of problems.
  #29
Old 04-30-2016 | 04:13 PM
bmwr606's Avatar
bmwr606
TG
on my cms all4, recommended tire pressure is 32 psi for all tires
i borrowed a tire pyrometer from a racer friend and ended up at 42 psi front and 37 psi rear (cold) if you like the rear to be loose, add a couple more psi rear, but wear will suffer some
using 42 and 37, rotating every 4000-5000 miles, with over 15,000 miles on my PSS tires, they are wearing evenly across the tread and all 4 tires are worn the same amount, about 1/2 of usable tread remains
  #30
Old 05-03-2016 | 07:46 PM
TG.'s Avatar
TG.
Originally Posted by bmwr606
TG
I took note
angeltrain31
06-12-2016 05:58 AM
ti22fjc
23
04-25-2016 05:42 PM
jmward2008
03-24-2016 05:26 AM
JWA
03-23-2016 08:37 PM
mini4mo
03-23-2016 04:33 AM
Quick Reply: Need new summer tires
