Ditching run flat tires - why?
#26
My little story - grab some ...
Bought my (sig) MCS almost 3 months ago as CPO MINI turned-in after 3-year lease with 17.7k miles. At that time, I figured the OEM Conti runflats had recently been replaced due to remaining tread and low wear. As stated here 10 days ago, I planned on replacing them with non-runflats - possibly in combo with more visually interesting wheels than 17" silver Conicals. At the rate I'll accrue annual miles, it would take quite awhile to wear out those runflats.
OK so last weekend, spotted a Phoenix area CL ad 75 miles away for set of GY Eagle Sport AS non-runflats "removed with less than 11k miles before returning leased vehicle". So I wrote asking about car those tires came from. Yep, very same car. I got those tires today for not much $$ and plan to have them installed tomorrow. My objective is for reduced NVH vs increased handling response. There are probably better choices out there than what I bought but "price of admission" for me to compare runflats to non-runflats is low. BTW, I decided to scrub purchase of new wheels since 17" JCW style would cost prox $1200 set plus sensors/valves if I didn't transfer from existing Conical wheels. I'm gonna hit the "easy button".
#27
Runflats don't assure you anything when it comes to road hazards...ditch them, save your money, and enjoy your improved Mini.
#28
I'm not sure what you mean by this. More weight, low and at the corners should help handling. Weight high is detrimental to body roll and overall handling. Maybe I've missed your meaning though.
#29
I'll second the issue with finding a tire shop that will deal with runflats.
My options are limited when it comes to tire shops here, even my mechanic, who is one of two guys certified to work on MINIs in town, doesn't have the "proper equipment" for dealing with runflat tires. As best I can tell, no one does. There's always a risk when they take the tire off of the wheel that the bands inside it could break, or so I was told at one tire shop. They asked me to sign a waiver releasing them from liability before they would even touch my RF tires.
#30
I race my car in AX. Yes my non RF's are needed for that. One they are lighter and two I put on wider tires that are needed. For DD that unsprung weight is not noticeable. I also disagree with most on here that my RF's are actually a BETTER ride than my track tires. Having said that most wouldn't buy what I use for the track as there DD tires so there may be other options for a non RF that are better for DDing. I can speak with intelligence and experience, when comparing MY run flats to MY non runflats the ride is far better with the RF's and the handling around town or even in the canyons is just fine and the Mini experience is not hampered. When my RF's go bald, I will be buying the exact same set.
#31
Weight at the corners is not a good thing. Unsprung weight negatively affects handling. In fact, wheel/tire weight is the worst (relative to rotors/calipers, for instance) as it is rotating mass vs. fixed...so it can hinder acceleration/deceleration. Do you feel it on a Mini? Not sure, and I have no personal experience. On my X5, with the significant weight difference between the two tires, absolutely. Especially since my 21 Super Sports are wrapped are lighter, forged alloy wheels vs. the heavier, cast alloy on the 20s.
#32
#33
#34
Won't dispute that increased unsprung weight can help ride quality...it allows better absorption of irregularities in the road. That said, I've found the runflats I've experienced to be jarring with their thicker sidewalls and not really something that enhances comfort. Not all tires are created equal, so I won't go out with a general comment that no RFT can be comfortable. Glad you found something that works for you.
Having said that you bring up a good point. I wonder if the extra weight of my DD set is offsetting the lighter non run flats. Meaning I think I beleive in what you said. The heavier RF's make the drive nicer than my lighter non RF because they are heavy and help absorb the bumps and cracks better. I guess I never thought of it that way.
#35
Runflats have stiffer sidewalls to support the cars weight when the tire is deflated; some more, some less. Performance tires have stiffer sidewalls to minimize tire flex under extreme cornering forces; some more, some less. Neither is designed to provide the best possible ride. You can't judge a book by its cover or a tire just by its category.
And then there are all of those variables in suspension design and condition to mess up whatever too-simple conclusions one might be tempted to reach.
#36
#37
Warren2185 (08-01-2019)
#38
Probably going to depend on what car you are talking about. I did this on a 2011 Countryman with the specialized adapter, MB compact spare, pump etc. When my son got a flat, he couldn't remember what I had told him about using it and he called for tow and the driver was clueless on how to use the set up. I cried and laughed at the same time.
#39
Why would it be a hassle for a tire shop to deal with a run flat tire? The equipment used to remove or mount the tire is the same? What part was the hassle?
#40
My 2019 Mini came with run flats and I have zero complaints. They handle the potholes in New Jersey just fine and they drive quiet as well. Each tire is $145 bucks.
My commute to work is 40 miles each way and I like knowing that if I get a flat, I can drive home with no problem. I bought a full size spare rim + tire tire for my long trips that I keep in the garage. When I am ready to take a long trip I just it in the back.
#41
resurrection of a thread from 2016 .....
but there are new/current points I suppose . . .
runflat issues have been in the top 5 topics since this site began (wanna discuss oil change interval recommendations? )
search and find MANY MANY discussion and opinions . . . if you want a donut, several vendors will sell you one. (https://www.outmotoring.com/mini-coo...gen1-gen2.html) READ DETAILS before purchase!!!!!
p.s. runflats have bailed Mrs out of trouble on multiple occasions. She LOVES them. TRUE, she is not as much of a car enthusiast as some - but she DOES drive a R-59 roadster. Recently had to re-tire and when asked if she wanted r/f again I got the 'are you crazy' look. She's on the Bridgestones for about a month now ... we got over 32,000 out of the Conti's it came with.
}}} WRT to AAA comments ...... all they are gonna do for you is TOW unless they can do an onsite plug. This IS better than being stranded. I've waited two hours for a AAA tow. With r/f I drove to a comfortable waiting place
If the issue is plugable you can get out of there as fast with http://www.dynaplug.com/ and a pump versus 'slime' and not crud up the inside of the tire and TPMS sensor
(and would your Mrs or kids know how to deal with either ... plug ... slime ... pump ????????) {{{
#43
My Clubman has a tire well, but it is filled with a styrofoam insert that holds the lug wrench, tow eye, etc. Don’t know if it fit the 205/45-17 tire that my car has. Anyway, I’m on non-runflats and have a sealer/compressor kit.
2010CHILI
10-05-2016 09:45 AM
TC Mini
R55 :: Clubman Talk (2008+)
05-16-2016 09:48 AM
iterator5
05-14-2016 09:06 AM
