Soft brake pedal
this typically means some air got into the system
I'd go to a GOOD TRUSTED shop and have the system flushed and the fluid replaced ......
[actually I'd do it myself but ......]
rotor replacement has ZERO impact on this question ......
OTOH many threads about the need to replace the rotors with every pad change
and ones about checking the need for pads yourself
I know they are there
I posted them .....
I posted them .....
is this normal for a countryman, I think there maybe air in the system because when I pump a couple of times prior to stopping, the pedal gets hard and higher.
Is the system the same as other vehicles .. pump the pedal and bleed one wheel at a time until the air in the system is all gone.
thanks
thanks
if you get air into the ABS system there are other problems
so unless you are 150% sure about doing this correctly it may be best to let the dealer (or other brake place) handle it. I understand when the dealer does it there is actually a computer function that they can plug in that deals with ABS issues. I bleed the system in my 79 no problem-o ... and take the MINIs to the dealer!
I posted them .....
I posted them .....
