17x8 wide??
Have your cake and eat it too?
Originally Posted by MSFITOY
Is there such a thing as a 17"x8", 4x100mm wheel for the Mini? Harder yet, can I get them in flat black?
17 pounds for even that size is good but not great. Lowest are 14 and under but you will pay quite a bit more for that lighter weight. I notice you didn't specify the price so I hope you are willing to pay alot to get a large diameter very light rim and pay even more to powercoat them black if they do not come in that color (about $60 each).
At edgeracing.com under 5Zigen wheels I find-
Fn01r-c in flat black and hyperblack in 17x8" but in 4x114 bolt pattern.
To get 4x100 you have to go bigger and get 18x7.5" +43mm offset 18 pounds $222 each which is not bad if you like 5 spoke designs.
![](http://edgeracing.com/images/wheel/5zigen_fn01r-c_(flat_black)_angle.jpg)
See http://edgeracing.com/wheels/flik/
If you don't mind Flik Tdr-b in 17x7" offset +38mm 15.5 pounds $155 each flat black
Is there a reasone why you need 8" wide rims? Need a particular size tire? If you go with 225/45-17 you'd likely rub.
At tirerack.com there aren't many black wheels. Just looking there are no 17x8 rims
Kosei K1 Racing 17x7.5" et +45mm 16.3 pounds $179 each silver or white
Kosei K1 TS 17x7" et +42mm 14.1 pounds $199 each light grey or silver
SSR comps 17x7.5" et +42mm 12.8 pounds $355 each anthracite or silver
SSR comps 18x7.5" et +42mm 14 pounds $399 each anthracite or silver
SSR GT1 17x7.5" et +45mm 16.5 pounds $339 each silver
SSR GT1 18x7.5"et +40mm 17 pounds $329 each silver
and more
Originally Posted by minihune
17x7 or 17x7.5" is fairly easy to find in 4x100 but most will weigh more rather than less.
and more
and more
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
Originally Posted by d6-mcs
Do i really have to do this again. my god, i am running 17x8 in front and 17x9 in rear. might not be black but not hard to change that. and yes they are 4x100.
chris
![](http://www.imagestation.com/picture/sraid133/p8164f61ddbe0e8ef86e48faea29b75d5/f788336d.jpg)
chris
I have seen your post before and actually have filed your photos, but you leave me hanging always.
Just WHAT size are these wheels??? I mean to ask what make and what offset are they?
How about tire make and size?
The car looks lowered, how much and with what?
Thanks much!
Originally Posted by onasled
Chris,
Thanks much!
Thanks much!
later
chris
Originally Posted by iguigu
Call this guy...any size u want.
[font=Arial][/font]
[font=Arial]Steven Lin
iForged Performance Alloys
Phone: 714.484.1070 Ext. 112
Fax: 714.242.9071[/font]
[font=Arial][/font]
chris
. I AM NOT GIVING OUT THE MAKE. i dont want to be one of those guys that everyone else has the same wheels and that everyone copies. took me 3 months to find the right wheels, and anyone else can do the same. any wheels that is wide you are going to be spending from 400 and up a wheel.
![Roll](https://www.northamericanmotoring.com/forums/images/smilies/roll.gif)
The wheels are Keskin KT4 New Racer's. http://www.tmtuning.com/main/html/main.html
17x8 = $295.
17x9 = $319.
![](http://www.tmtuning.com/wheels/images/WH-104_1.gif)
[font=Arial, Helvetica, sans-serif][size=1]
[font=Verdana, Arial, Helvetica, sans-serif]KESKIN KT4 NEW RACER'S
[/font][font=Verdana, Arial, Helvetica, sans-serif][size=2][font=Arial, Helvetica, sans-serif][size=1](pronounced = 'Kiss'-Kin)[/size][/font][size=1]The KT4 wheel set from Keskin features a aggressive multi arm web design with sharp contour in a classic style that looks good on any Volkswagen. [/size][font=Arial, Helvetica, sans-serif][size=1][font=Arial, Helvetica, sans-serif][size=1][font=Verdana, Arial, Helvetica, sans-serif]The bolting holes are also capped behind a contoured front cover. Like all Keskin wheels made in a single forge and CNC 'd to a perfect finish[/font][/size][/font][font=Verdana, Arial, Helvetica, sans-serif][size=1] notoriously tuff wheels that last a lifetime.[/size][/font][/size][/font][/size][/font] [font=Verdana, Arial, Helvetica, sans-serif]To view the available sizes, offsets and bolting patterns look below. [/font][font=Verdana, Arial, Helvetica, sans-serif][size=1]Also for a additional $120.00 you can get these wheels in a full chrome polished finish! Just let us know when you order. All Keskin wheel sets come with free high quality wheel bolts, hub centric rings and a set of wheel locks, courtesy of TM TUNING. We want to protect your investment! All Keskin wheels are made in Germany, TuV approved and have been tested by TM TUNING. These wheels are also available as a wheel and tire package, TM TUNING offers the best Fulda or Toyo tires.[/size][/font][/size][/font]
[font=Arial, Helvetica, sans-serif][size=1] 7.5 x 16 || ET NA[/size][/font][font=Arial, Helvetica, sans-serif][size=1]US $ 239.00 / pc.[/size][/font]
[font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]order no.: WH-104-1[/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][size=1] 9 x 16 || ET NA[/size][/font][font=Arial, Helvetica, sans-serif][size=1]US $ 262.00 / pc.[/size][/font]
[font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1][font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]order no.: WH-104[/size][/size][/font][/font]-2[/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][size=1] 8 x 17 || ET NA[/size][/font][font=Arial, Helvetica, sans-serif][size=1]US $ 295.00 / pc.[/size][/font]
[font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1][font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]order no.: [/size][/size][/font][/font][font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]WH-104-3[/size][/size][/font][/font][/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][size=1] 9 x 17 || NA[/size][/font][font=Arial, Helvetica, sans-serif][size=1]US $ 319.00 / pc.[/size][/font]
[font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1][font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]order no.: WH-104-4[/size][/size][/font][/font][/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1] 8.5 x 18 || ET 15 / 30 / 35[/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][size=1]US $ 385.00 / pc.[/size][/font]
[font=Arial, Helvetica, sans-serif][size=1]order no.: [/size][/font][font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]WH-104-5[/size][/size][/font][/font]
![](http://www.tmtuning.com/layout/buttons/cart_over_sm.gif)
[font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1] 9.5 x 18 || ET 20 / 25 / 30[/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][size=1]US $ 421.00 / pc.[/size][/font]
[font=Arial, Helvetica, sans-serif][size=1]order no.: [/size][/font][font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]WH-104-6[/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1] 11 x 18 || ET 10 / 15 / 35[/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][size=1]US $ 465.00 / pc.[/size][/font]
[font=Arial, Helvetica, sans-serif][size=1]order no.: [/size][/font][font=Arial, Helvetica, sans-serif][font=Arial, Helvetica, sans-serif][size=1][size=1]WH-104-7[/size][/size][/font][/font]
[font=Arial, Helvetica, sans-serif][size=1][/size][/font]
![](http://www.tmtuning.com/wheels/images/EXkeskinBanner.gif)
![](http://www.tmtuning.com/layout/logos/tmt_bar_red_450.gif)
hey thanks alot man, i really wanted everyone to know that you ********. i didnt want everyone to know and that is not hard to find but that you have to search for them. good luck getting them. i had to get them special ordered anyway due to the offsets. thanks
chris
17x8 = $295.
17x9 = $319.
[/size][/font]
chris
17x8 = $295.
17x9 = $319.
[/size][/font]
Take a pill or something man. It aint that big of a deal.
Hey, let's lighten this up. Anyone seen or have pics of spinners on a MINI???? What's the WORST looking wheels you've seen?
![Cool](https://www.northamericanmotoring.com/forums/images/smilies/cool.gif)
Juveniles don't like to share...and often become upset when they have to. They often lack respect for others, as was also indicated by his private message to me, which I cannot share because of it's very offensive language.
The fact is, he is the one who posted the mfg, and source for the wheels here:
https://www.northamericanmotoring.co...ad.php?t=25272
If someone wishes to keep a "secret", do not post it on a public forum.
ludrof11
09-27-2015 01:46 PM
M7Speed
09-16-2015 10:05 AM
