Can I put 15 inch wheels on my 2011.
Do you have an S or the base Cooper model? The non-S will fit 15" wheels (it was the standard size and 16" wheels was an optional upgrade). If you have an S, original MINI 15" wheels won't fit over the larger S brakes. There may be some aftermarket 15" wheels that can clear the S brakes, or using wheel spacers might add enough clearance to make it work.
bobbi.steines (08-27-2017)
The question are the brake calipers. Someone else should chime in but meanwhile you might be able to see how much space there is between the rim and the caliper. Would think that if you have at least an inch, the 15's would work.
You are aware you need to buy new rims correct?
