Help with finding center caps
I've been in vain search of a simple 56mm spring steel center-hub cap for my Team Dynamics wheels. Preferably finished in nickle or chrome...hell, at this point I don't care if it's pink plastic
I can picture it clearly and have built a simple math model to illustrate. If any of you know where I can find such a thing I'd greatly appreciate it.
![](https://www.northamericanmotoring.com/gallery/data/500/7338cap1.jpg)
![](https://www.northamericanmotoring.com/gallery/data/500/7338cap2.jpg)
Thanks in advance
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
Thanks in advance
![Cool](https://www.northamericanmotoring.com/forums/images/smilies/cool.gif)
on
Looks very much like the centre caps on my BBS CH wheels......not sure about the dimensions though. Maybe Alex at Tire Rack could point you in the direction of something suitable ? I was thinking about something similar to fit a set of Volks....if you find anything generic in various diameters I would be very interested. Good luck.
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
Center caps come in all different sizes... do you know if they are
anywhere close to the Rota caps? If so, try http://www.subydude.com/parts/index....eelaccessories
Originally Posted by MSFITOY
I've tried Alex, the net, Discount Tire, etc, etc...
I can't believe this simple piece is so hard to find...
Originally Posted by Cynamini
Hey MSFITOY! I have the same wheels and I have found that you can attach the MINI stock caps into them by using pvc pipe and epoxy. I have white wheels so I didn't need to paint the pvc. The fit is perfect!
Good Luck on your quest...been there.
-Cyn
![Grin](https://www.northamericanmotoring.com/forums/images/smilies/grin.gif)
-Cyn
![EEK!](https://www.northamericanmotoring.com/forums/images/smilies/eek.gif)
Team Dynamics Inc.1885 S. VINYARD AVENUE SUITE 4 ONTARIO CA 91761
909 947-0114
Hope this helps...
Originally Posted by kazlot
I just ordered a set of Team Dynamics wheels from these guys and the center caps will be shipped in a few days because they have been on back order They have shipped my wheels minus the center caps.
909 947-0114
Hope this helps...
909 947-0114
Hope this helps...
Update...I found a car with Rotara wheels and the center hub looks to be a little larger than 56mm. I don't know if the hole is small than that or it has a very small flange. If anyone knows, please do tell.
No way
Which wheel cap did you use? I thought I checked my Slites a while back and seem to recall they were too large. Can you elaborate on how you mounted yours on? Thanks
Pics would be worth a million words...
![tongue](https://www.northamericanmotoring.com/forums/images/smilies/tongue.gif)
![Roll](https://www.northamericanmotoring.com/forums/images/smilies/roll.gif)
Ahhh, the wonders of pvc pipe.
![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
I don't have a really good close up picture right now...but I'll try to attach one for some reference.
Good Luck!
-Cyn
Sorry, probably should have mentioned such things.
Good Luck!
-Cyn
Originally Posted by Ozbone
I had a set of TDRs on my Passat and I'm pretty sure that I used a chrome plastic centercap purchased from VW which was dished to accomodate a VW emblem backed with adhesive. I strongly suspect other companies also use 56-mm centercaps.
VW/Audi and BMW E30 center bores are 57.1mm. Some careful filing and fitting of these might do the trick.
08-07-2015 05:55 AM
08-05-2015 02:11 PM
08-05-2015 02:10 PM
