Toyo T1S and Yoko Parada
on
I've had the 16" Parada Spec2s for about a year now. No complaints. Mind you, I'm not a track racer. But on the streets as cornering, high speed comfort, stability, handling and such goes, they rock. I haven't tried the Toyos, so I can't really compare them personally. They have a great tire wear rating too, providing that you treat them right.
Cheers,
Cheers,
spike friedman
Originally Posted by Ryephile
The Toyo is generally regarded as a Max performance tire, whereas the Parada2 is a step down in the hierarchy. You'll probably see that in the pricing too.
Spike
Last edited by Ryephile; 11-08-2004 at 07:26 PM. Reason: um, no random advertising plug, thank you
Originally Posted by S1monLM
Which one you guys recommend?
If for 17" mostly street then I would pick:
215/45-17 Toyo T1-S for very good handling, light weight, and less road noise than the Parada Spec-2 (a more common choice in 215/35-18)
The Spec-2 tread does look aggressive
If your looking at Parada's, consider the sister tire AVS ES 100 too. These seem like everybody's favorite tire. Mine were great too.
For my next tire, I'm leaning towards the T1S too, especially now since they've ceased making 'em (replaced by the T1R) they're cheap.
hehe, reviving old threads are great fun.
i have the T1-Rs, they are pretty good, but not great, well they are good enough for me, I have to go in corners pretty darn fast to make them squeak. car and driver did a tire test with all the big name sport tires and the T1-Rs did not hold up to the competition. you should look that article up.
Car & Driver article: http://www.caranddriver.com/features...the-tread.html
EDIT: just purchased a set of the Goodyear Eagle F1 GS-D3s in 225/50/16... for $98/each (regular price $148!) as I've only got about 4000 miles left on my set of T1-Ss. Tirerack is having a special in certain sizes.
