Feasibility of brake ducts w/o using Fog Light housing
For an R56 S (N14) how feasible is it to run small ducts (25MM Diameter) by cutting out holes in the air dam?
I have fog lights and like them. Would rather leave them be. Although unless advised otherwise I'd use the cut out to access bulb as part of the route for ducts.
Any advice?
This is being done in preparation for Chin Motorsports Sebring Raceway open track day (7.5 hours). I have new EBC Yellow stuff pads for front and existing Hawk HP+ pads in rear. Switching to drilled/slotted rotors from blanks (Hawk Sector 27). I am primarily concerned with the Yellow stuff's longevity given what I've come across searching in this very form.
Any advice?
This thread doesn't address installing the duct openings in the air dam, but it does cover the routing of the duct hoses.
https://www.northamericanmotoring.co...or-r56lci.html
I mounted two inch ducts in my lower air dams for track days during the summer of 2017. My car is lowered about an inch on NM Alpha springs. They rubbed on the ground, but not too bad. I didn't reinstall them this summer because I had too many other things going on.....and I didn't like how I had to route the hoses around the suspension....there are some pictures of my setup in the thread above. Also, I installed some JCW aero ducts in my front bumper....I have the S front bumper, but I was able to get them in there and because of the aftermarket grille, the different shape doesn't show.
You might consider mounting some scoops under the a arms. You probably wouldn't have any rubbing issues.....
http://forums.pelicanparts.com/porsc...-ductwork.html
These are NLA, but something like them -
https://new.minimania.com/part/NMB40...2-53-Cooper--S
The scoops shown in the link above are available elsewhere, but I can't find it right now.
I've used EBC red stuff on the front for track days, and they've held up pretty well. Best of luck, and please keep us informed!
miniforozzie
03-10-2014 02:17 AM
Interior/Exterior Dually D2 LEDs mounted using stock fog light housing
cambo
11-21-2013 12:30 PM
Drivetrain feasibility of e85 mix with booster pump
PinkMiso
05-28-2013 03:53 PM
