17x7.5 45mm Offset Fit With H-Sports?
I am interested in these wheels:
http://www.rotawheels.com/subzero.htm
Do you think they will fit? If so would I need to change out my tires with them? Ive got the 205 45 17 Kumho tires on right now.
Originally Posted by JCampos
Ya.... sfjames told me that the guy he talked to at the shop said that the 17/7.5 wheels would fit the same way his car does with 17/7 and 15mm spacers. It ALMOST rubs with his M7 springs so I figured that if I had 215s they would rub.
Thanks for the input. Appreciated
Nothing major and doesn't usually requite trimming but some rubbing which you can hear or feel as scraped up plastic on the inner wheel well areas facing the tire's outer edge.
Usually you don't need spacers for this offset. Otherwise the rims are fine, just wider than stock.
Wait a minute.....
I run the Kosei 17x7.7 with 215/45 and I rub pretty bad. I have actually rubbed a good size hole through the driver side rear well in the first 200 miles of driving. No damage to the tire at all but I do have to peel of the melted plastic from it.
Maybe Minis are that different that some will and some won't. I am using the H-sports also.
Originally Posted by onasled
Wait a minute.....
SosoMINI
11-22-2015 03:17 PM
Mini'mon
08-16-2015 04:15 PM
