Run flat has a nail
Old 11-23-2004, 07:12 PM
ninjamini's Avatar
ninjamini
ninjamini is offline
Run flat has a nail
So here I am again with one of those little annoyances in life...a nail in my tire. My mini dealer told me that I had one and I would need to replace the tire. With only 5500 miles (3 months) on them I am a little unhappy. Here is my questions:
Can a run flat be fixed in a nail is in the tread?
If I do replace the tire Do I need to use mini or can I go to a tire center and have them do it? I was a little concerned cuz its a runflat and the weights are inside the wheel and not on the lip.
Any thoughts? Its the 16" 195-55 R16. Thanx.
Old 11-23-2004, 07:27 PM
tchangmo's Avatar
tchangmo
tchangmo is offline
If the nail is in the tread, it can be fixed like any other tire. Any good tire shop that has the equipment to handle runflat beads will be able to do the work. Ask if your tire shop can handle runflat tires. Mini dealers charge exorbitant prices for tires and tire work.
Old 11-23-2004, 09:28 PM
resmini's Avatar
resmini
resmini is offline
It's ridiculous that people keep being told a flat on a run-flat tire can't be fixed. No different that fixing a flat on a non-runflat tire. Of course you should stay away from the dealer for tire repairs, the prices are almost always incredibly high. Find a good tire shop and stick with it. I've been using the same shop for over 20 years. I trust them.:smile:
Old 11-23-2004, 10:07 PM
mbabischkin's Avatar
mbabischkin
mbabischkin is offline
Moved this to the Tires/Wheels forum to make sure that the experts get to see it...
But I was under the impression that the only time a run-flat had to be replaced do to a puncture was when the hole was in the sidewall. Heck I've got a patch in the tread of one of my runflats, the local Goodyear shop did it for like $11 a year ago...
Old 11-23-2004, 11:48 PM
BigBlueOx's Avatar
BigBlueOx
BigBlueOx is offline
Mine was patched too when a bolt/screw went through mine. That was last year, no problems with it. I'd say it's safe.
Old 11-24-2004, 03:28 AM
sndwave's Avatar
sndwave
sndwave is offline
Coordinator :: Gulf Coast & Panhandle MINIs
Same thing happened to me. I took it to the local Firestone dealer and had it fixed for $12. I used it for another 8 months including a great week at the Dragon. After that I moved to standard tires because the run flats were almost out of tread.
Old 11-24-2004, 04:30 AM
ncdave's Avatar
ncdave
ncdave is offline
So long as the nail is completely in the thread portion, it can be fixed. I recently had to replace my runflat but only because a chunk of metal really did a job on the tire. Good Luck!
Old 11-24-2004, 04:49 AM
BuckeyeMCS's Avatar
BuckeyeMCS
BuckeyeMCS is offline
When I had mine replaced it was because the nail was closer to the edge of the thread than the width of a thumb.
Old 11-24-2004, 04:58 AM
spav's Avatar
spav
spav is offline
I've got a screw in my tread right by the side wall. It's not leaking, though. At the cost of a run-flat it can stay there for a bit till it's time for replacement.
Old 11-24-2004, 05:15 AM
ninjamini's Avatar
ninjamini
So why would the dealer not repair the tire? Why would he tell me to purchase a new one?
Old 11-24-2004, 05:24 AM
Rev. Limiter's Avatar
Rev. Limiter
Rev. Limiter is offline
Simple:
I picked up two sheetmetal screws in one of mine, but it was repaired just like any other tire. I understand, though, that the tire lost its "Z" rating (whatever that is), and I now have to keep it below 130mph...
Old 11-24-2004, 05:29 AM
ninjamini's Avatar
ninjamini
That sucks. Below 130.
Old 11-24-2004, 05:42 AM
resmini's Avatar
resmini
resmini is offline
Another simularity between run-flats and non-runflats, neither should be repaired if the problem is in the sidewall, only in the tread.:smile:
Old 11-24-2004, 06:06 AM
maneeto's Avatar
maneeto
maneeto is offline
I got a nail in one of my runflats a over a year and 20,000 miles ago. I've got a plug kit I bought from Walmart a while back that I paid less than $7 bucks for! I plugged it myself at home and its been good to go. Some of these places are ridiculous. I get so angry when I hear about dealers saying that you have to replace the tire ! Thats ridiculous.
Old 11-24-2004, 07:36 AM
eurazn's Avatar
eurazn
eurazn is offline
similar to maneeto, I went to a local advanced auto parts and got myself a tire repare kit. I got two nails in the sidewall, yet my the tires are still running fine after I fixed it. FYI: I think my dealer charge $10 to fix flats, but since mine was in the sidewall they told me to replace the tire. Cost too much so I took a cheaper alternative GL
Old 11-24-2004, 09:35 AM
kenchan's Avatar
kenchan
kenchan is offline
Repairing tires on the sidewall is risky...but since they are reinforced runflats maybe that might be okay.... i wouldn't do it though.
Old 11-24-2004, 09:55 AM
sfjames2's Avatar
sfjames2
sfjames2 is offline
If the nail is is the tire treads, buy a plug kit for $5 and plug it up. Very easy to do.
Dealer told us we needed a new runflat to and that it had to be ordered .
We ended finding a whole new set of tires and s-lites on ebay for around $500. good luck
Old 11-24-2004, 01:38 PM
Alex@tirerack's Avatar
Alex@tirerack
Alex@tirerack is offline
patching still required
This plug idea is a temporary fix, you need to get the tire in for it to be dimounted , patched, and remounted as soon as possible. Wax plugs do not keep moisture out,
moisture+steel belts = issues later.
Alex
Old 11-24-2004, 02:33 PM
cristo's Avatar
cristo
cristo is offline
Alliance Member
never seen a wax plug, don't think i want to. have used rubber ones,
usually coated with rubber cement.
Old 11-24-2004, 02:39 PM
sfjames2's Avatar
sfjames2
sfjames2 is offline
[QUOTE=cristo]never seen a wax plug, don't think i want to. QUOTE]
that's what I thought LMO
Old 11-24-2004, 07:05 PM
number_twelve's Avatar
number_twelve
number_twelve is offline
If you live on the west coast, take it to Les Schwab and they'll fix it for free.
If you have a tire with a patch in it already, it will reduce the speed rating to the next speed rating under it. If there are 2 or more patches/holes in the tire, you are only supposed to drive at posted speed limits and not higher. More than 2 holes, get a new tire.
But definitly don't settle for a plug, only a patch will correctly fix the problem.
Old 11-25-2004, 05:49 PM
mycpr_s's Avatar
mycpr_s
mycpr_s is offline
i ran over an 8 inch nail on the street. ouch!!!!
Old 11-26-2004, 03:24 PM
fishey72's Avatar
fishey72
fishey72 is offline
I just played this tire/nail/run-flat game. Especially when the tire place destroys the bead when removing the tire. So then it truly was not repairable.
Old 11-27-2004, 12:40 PM
ScottinBend's Avatar
ScottinBend
ScottinBend is offline
If the tire dealer is really aware of the fact that he is dealing with a runflat tire, he will more than likely not repair it. Reason.......there is no concrete way of knowing how long the tire has been "flat". Run-flats are limited in the amount of time/mileage they can be run "flat". The dealer may not want to take the liability of repairing a tire if he doesn't know the extent of the damage.
Old 11-27-2004, 05:39 PM
resmini's Avatar
resmini
resmini is offline
This has a bit of logic to it. I think you could probably look at the tire and tell if it's OK, but there could be hidden damage. Perhaps the runflat, once repaired, should become a non-runflat, i.e., change it when the low-pressure alarm comes on.:smile: In all probability though, the tire is likely fine to run-flat again.
Quick Reply: Run flat has a nail
