235/50/R18 on F60
235/50/R18 on F60
Looking for an AT tire to fit my stock wheels, but only AT I can find is a bit larger (not much though, 235s vs 225s), the Falken Wildpeak AT.
I have a 2018 Countryman All4 S, anyone running this size on stock wheel by any chance? Wanted to make sure I'll have no rubbing.
Thanks!
Thanks!
Thanks for the link, I use https://www.miata.net/garage/tirecalc.html, but the one you sent me is better.
I am having a hard time finding another F60 owner with this tire size, and even if only 1/2 inch difference I would still like to check with someone already running this size before ordering the tires.
When i was looking for large winter tires, i went to my friendly independent family owned and run tire store.
I explained what i wanted to do and they helped me by fitting used tires on my new winter wheels and then filling the car with bodies until the suspension was bottomed out (it took 4 people in the seats plusc2 more sitting on the boot lip!)
Using this method, i found that the 205/70R16 fit with no interference but the 215/70R16 rubbed in front at full lock. So they ordered me the 205/70R16s.
PS the tire shop also vests tirerack on price PLUS they do not charge me freight. Win-Win for me.
SunBird (12-30-2019)
So did you wind up ordering the 235 50? I don’t see why that tire wouldn’t fit we have the room and it’s close to stock. I’ve been reading and reading also. I just purchase 18x8 et40 wheels and H&R 1.2 drop springs and am looking for a tire also. I wanted 245 50 and read many things. But safely it looks like a 235 50 should be fine.
https://www.wheel-size.com/calc/?whe...cl=70mm&sr=0mm
