Rims cracked, need quick solution!
Hey everyone! I’m new to the forums and was referred to by a fellow R53 owner in my town. So I have a little issue. I noticed one of my rims are cracked and another one is also bent. Instead of spending money to get these rims repaired, I found a set of 2013 Cooper S wheels online for cheap. I know they have the same 4X100 lug pattern as the R53 and run a 195/55/16 tire. Will they be able to fit on my R53 without any issues? Below is my R53 I got recently and below that is the wheels I’m looking to put on.
Thanks for all your advice in advance!!
S-winder wheels
These should fit your R53. They are R56 wheels, but the only difference is a 14mm lug instead of 12mm. I’ve used R56 wheels on my R50 before. Being 16”, you will get a taller sidewall, softer ride, less possible problems bending and breaking wheels! Here is a cross reference too:
https://libraryofmotoring.info/facts/wheels/#16
Thank you for the response!! Unfortunately the person selling the wheels does not have the lugs, do you have any suggestions on where I could by them?
You can use the lug bolts that came on your car,
Veearesixx (01-16-2020)
The following 2 users liked this post by iwashmycar:
ECSTuning (01-24-2020),
iwashmycar (01-24-2020)
Because all the Factory-MINI 4x100 wheels are "Hub centered", with a 56.1 Center Bore ... you can use the smaller conical seat 12mm R53 wheel-bolts with the larger 14mm bolt holes on the R56 wheels without issues.
The offsets on the wheels are also all the same in the respective wheel diameters.
I would not have confidence in that with an aftermarket wheel.... In fact... I will not use a lug centered wheel on any car.
You should be good to go !!
