Lug conversion kit
Old 12-26-2004, 07:50 PM
conehead's Avatar
conehead
conehead is offline
Definatly go for the red locktite if you can. The blue will work in a pinch but this isnt't something you want to leave to chance.
  #52
Old 12-26-2004, 11:26 PM
lexbomb's Avatar
lexbomb
lexbomb is offline
Dan, thanks for the discount. I'll order mine next week when I get back from a short trip.
_______________
lexbomb
  #53
Old 12-27-2004, 11:08 AM
Santa's Avatar
Santa
Santa is offline
Are the "Chrome Open" lug nuts with "Security" 17mm hex drive or 3/4" hex drive?
  #54
Old 12-27-2004, 11:25 AM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
It is 13/16 but includes a 3/4 adapter. The chrome open security is a special order and may up to 2 weeks to arrive.
Dan
  #55
Old 12-27-2004, 11:55 AM
OctaneGuy's Avatar
OctaneGuy
OctaneGuy is offline
Thanks Dan! I just submitted my order. I ordered the standard 37mm threads--I hope that's the right one for my Stock OEM 5 Star wheels.
Richard
  #56
Old 12-27-2004, 11:59 AM
Santa's Avatar
Santa
Santa is offline
The regular Type F chrome open lug nuts are 17mm hex drive and fit the stock lug wrench. Is that correct?
  #57
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
Richard
37mm is the correct size for a stock wheel with out spacers
30 is good for some aftermarket Wheels that require less thread (not many though)
and 57mm is great for wheels with spacers up to 9mm
  #58
Old 12-27-2004, 12:00 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
That is correct, They will fit the stock wrench.
  #59
Old 12-27-2004, 12:13 PM
OctaneGuy's Avatar
OctaneGuy
One more question. The only way I've been able to disassemble components glued with Red Loctite is by applying heat. Assuming that one day I get aftermarket wheels and I need longer studs, what's the recommended way of removing them?? Will I have to drill them out??
Richard
  #60
Old 12-27-2004, 12:26 PM
Hammer's Avatar
Hammer
Hammer is offline
Originally Posted by DrDiff
GREAT! Very pleased to hear this. This will be one of the firts mods I do once I get my MINI. That and the brake light mod.
What brake light mod is that?
  #61
Old 12-27-2004, 12:44 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
Wow...missed this thread altogether. Here's mine from BMP. More expensive than Pilo's But, I wanted black. These are 50mm with hex head. The nuts are 20mm long/forged/anodised alloy open type.
  #62
Old 12-27-2004, 12:59 PM
OctaneGuy's Avatar
OctaneGuy
Very nice! I like how those look!
  #63
Old 12-27-2004, 01:55 PM
RHT3's Avatar
RHT3
RHT3 is offline
Had studs. Got rid of 'em.
On my '03 Cooper S, thread-in studs came loose frequently, and came out when nuts were loosened. I've heard locally of MINIs breaking more than one studs during a track day. I use bolts on my Cooper S at the track and on my Vintage Formula Vee. I won't use studs on a car that was originally equipped with bolts again. I've never had troubles with bolts.
  #64
Old 12-27-2004, 01:59 PM
trplezero's Avatar
trplezero
trplezero is offline
what length bolts would i need with a set of 18" Roja formula 5's? im wanting in on this order.. thanks
000
  #65
Old 12-27-2004, 02:04 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
What material were the studs that they broke. I have done Auto X, Track Events, and Street in NJ (Large Pot Holes) with out issue. We use studs that are cold Forged Steel, and are zinc Plated for corosion resistance.
for the Roja's 37 mm should work if you are able to use the stock bolts.
Octaneguy. If they are not removable with the alen wrench, then you can drive a bit with hardbraking to heat up the brakes. That should allow the locktite to loosen enough to be removed.
  #66
Old 12-27-2004, 02:05 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
I can special order Black Chrome lugs if anyone wants, but there is a 1-2 week delay on them.
Dan
Pilo Racing
  #67
Old 12-27-2004, 02:50 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
Wiring up the rear fogs to come on with the brake lights (a two minute job). If you're worried about being punted at a stop light, like me...add an "intelligent flasher module" to your CHMSL Certainly priceless for peace of mind
  #68
Old 12-27-2004, 02:57 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
000
Looking at the Roja's You may be better off with a Tuner Style Lug, for 2 reasons. First, ther are smaller in diamater, and less chance of marring up your wheel, Second, they are installed with an alen type adapter, and are harder to steal.
  #69
Old 12-27-2004, 03:49 PM
Hammer's Avatar
Hammer
Hammer is offline
Did you know that when you press the brake pedal that the brake lights will not light up unless the key is in the "on" position? No other vehicle I have ever owned did this!
  #70
Old 12-27-2004, 04:06 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
Yes...that is odd
  #71
Old 12-27-2004, 05:29 PM
tontobird's Avatar
tontobird
tontobird is offline
Dan, just to clarify, the studs are still silver as pictured on your site, but the nuts are black?
Dan
Pilo Racing
  #72
Old 12-27-2004, 05:30 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
Yes, That is correct.
  #73
Old 12-27-2004, 05:37 PM
tontobird's Avatar
tontobird
O.K., thanks for answering my many questions. I don't care about the wait, I prefer black. Will the 17mm socket fit all styles?
  #74
Old 12-27-2004, 06:03 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
No problem with the questions. That is what vendors are here to help with!.
The 17mm stock wrench will only for the chrome open version. the others are 13/16, so you would need a wrench to remove the lugs.
  #75
Old 12-27-2004, 07:39 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
FYI...my BMP version uses a 19mm socket (for better leverage). The down side is that it requires me to carry the required socket so I just keep my torque wrench with my tool kit.
Quick Reply: Lug conversion kit
