Will 16x7.5 ET25 fit a stock R56?
https://www.wheel-size.com/calc/?whe...cl=15mm&sr=0mm
I don’t think the wheel offset will be your problem. A 195/40-16 tire is nearly 2 inches smaller in diameter than stock size! You’ll want to go with a 195/55, or a 195/50-16 at the smallest.
As far as the offset, you should be fine as long as you have adjustable rear control arms and front camber plates (or just slot the top mount holes). You’ll need to run slightly more camber (I’m running 2 degrees). I have 18x8 et32 215/40 which is almost identical in offset to a 16x7.5 et25. A 195 tire is pretty stretched on a 7.5. You would be better off with a 205. You will need to lower it from stock suspension for it to look right.
rexracerx9
Tires, Wheels, & Brakes
06-10-2010 09:38 AM
