Like the title states trying to determine if the bolt holes on the K1s are large enough for the 14mm wheel bolts. Unfortunately I have the 06 r53 with the larger bolts and can't find a definitive answer about if the kosei k1s will fit. Any help ??
Most of the threads on Kosei K1 seem to indicate that they are made for 12mm wheel bolts or studs. It might be good to check with tirerack.com to confirm this since they sell them.
Some MINI owners write about doing a stud conversion 14mm to 12mm before using the wheels.
