Slow leak and thoughts on repair
Hello all,
I have a slow leak on a rear tire and before I attempt to plug it I thought I get folks comments.
I understand proper way to repare is patch it from inside and no steel belt damage.
Running Yokohama 215/40 17, 2.5 yeasrs old on stock rims.
Cheers
Cheers
If you’re doing it yourself, there’s really only two options, patch or pump something into it, like Fix A Flat or Tire Slime.
My preferred method is to use a motorcycle tire patch kit made by Stop N Go. It has a steel gun that inserts mushroom shaped plugs. It’s not the easiest to use as you really need a good sized hole like one made from a roofing nail. So for a slow leak, that’s gonna involve opening that hole up to patch it. But once it’s plugged, it’s not gonna give out.
I have used Tire Slime with good results for slow leaks on an old Z car with aftermarket aluminum wheels that had a few slow leaks around the bead. It’s supposed to be harmless on sensors but so are patches.
http://www.dynaplug.com/ultralite.html
dynaplug .... have fixed many simple nail punctures with this over the years and never had a problem including run flats
roadrunner255 (09-13-2021)
You just state that you have a slow leak but don't identify the source of the leak. If it is, in fact, a puncture and you don't plan on competing in track events, then plug it. Don't use Slime or Fix-A-Flat. Best is to break the bead and plug from the inside out. If the tech is good and doesn't move the tire on the rim, it shouldn't need re-balancing.
