Is it "grab"?
Is it "grab"?
Has anyone else experienced this?
I have Falken Ze 512's on 15" R-82s that I use as my winter tires on my MCS. I recently "rotated" my tires back to front. (They indicate they are unidirectional so I didn't cross...) I noticed the car began to feel like it was drifting to the right when I released the steering wheel on a straight, level road. I checked the air pressure and they were all equal. I checked the alignment and found the toe was out a bit and had it adjusted. The tire shop said the caster was out of spec: left was just below the specified range and the right slightly more, but the difference between the two was within the specified range (only a .5 difference). Camber was witin specs. I don't recall ever hitting any big potholes or anything to damage the suspension.
Someone at work mentioned that sometimes tire manufacturing differences make one tire have more "grab" than the other. Could this be the case? They suggested I try moving the tire to the rear again and seeing if it stops. If it does, should I be concerned? If it doesn't, any other ideas? Unfortunately, I sold my S-Lites so I don't have another set of wheels to swap out to check -- maybe this is my excuse to do a little shopping...
Thoughts?
Thoughts?
Thoughts?
Thoughts?
Alex
I swapped the right side front to rear and it seems to have stopped pulling to the right. So what does that mean? Should I be replacing the tire that was pulling? Is that something normally covered under the standard tire warranty? Or do I just leave the tire in the rear and not worry about it?
Now I'm thinking I should swap the left side front to rear so the pairs have equal mileage.
Alex
Originally Posted by kenchan
but you said the problem went away when you "swapped the right side front to rear and it seems to have stopped pulling to the right."
it's not just the ABS sensor, you have a defective tire.
