215/55/16 tires
215/55-16 is outside the recommended ±3% variation from stock.
When your speedo reads 60 MPH you will be traveling 62.1 MPH.
http://www.miata.net/garage/tirecalc.html
Originally Posted by LeftyS7
Randy says 205/55 might work, 205/50s will work. 215/45s apparently will work.
My mini is lowered 1.5 " all around I auto-x with the 215/45-16s 42 offset no rub issues. So if yours is stock 1.5" taller and you run 215/55s same width,1" taller and .5" more clearance than mine.
on
Please read this first.............very informative.
http://www.chris-longhurst.com/carbi...yre_bible.html
Originally Posted by Minirox
Lefty
THANKS!
