Wilwood decision
if your going to stay with 16's, will both fit in the wheel? that might help you decide. if both do, then you always go bigger!
i just installed the 11.75 wilwood race kit- very nice kit and straightforward installation. Took out fog lights (don't need them in HI) & cut liner to allow airflow. With the 11.75 kit you'll have a two thick plastic washers that you will not use & lots of left over spacers. (close reading of all the part list will show parts that are included but not used for 11.75 kit)
I use 17" centerlines for street and 15 X 7 SSR comps for track. The SSR fit when car was up in air without rubbing but it was as close as one could get actually hitting. Figured it would rub when car was on ground and everything expanded with heat from track so i ordered 5mm spacers. probably could have gotten by with 3mm.
Let me jump in here, Mark approving.
Comparing the kits, the 11.75 or 12.19 will amount to about zip for brake torque. So forget the diameter issue. Even swept area difference is minimal.
These are the things you need to consider:
11.75 kit- Stainless Steel piston, non booted, HD, directional cast vane rotor, no zinc, no fluff.
12.2 kit- Alum pistons, booted, light weight, non directional rotor, drillled, slotted, zinc'd finish.
Weigh the value of each for your needs. Street will do fine on either, blingy rotors won't rust, all weather boots for salty roads, looks good. Track users will benefit from the HD rotor, boots a pointless arguement, no holes or slots.
It's not all about the rotor diameter. And think about it; the difference is only .220 radius. Less than 1/4"
But the rotor weight IS different and one DOESN'T have holes....And one is directional for improved air flow.
Like RW said; the E pad is far more suited for track use. Yes, you can run more streetable pads in the caliper as well on the way home from the track.
My car is a daily driver (midwest..rain, salt, etc) which will be active in a dozen track events a year.
Thanks!
My opinion, and from manufacturing kits since 1993, is that this proves a rather moot point in the big scheme of things. For those who live in the salt belt, drive the car year round, seldom wash it, and generally take poor car of their car it is worth considering.
On the other hand if you are acitive in track days and pretty much care for your vehicle, all you need to do is keep them clean of debri, keep the pads up to a 40% or more level and do some general maintenance and they'll provide years of service.
For those in the salt area (or lazy like me at time and don't clean things) consider the replacement parts cost as well; new FSL calipers can be had for about $150ea. In the most extreme case of the need to replace them in two years time due to conditions the replacment cost of $300 would prove very small vs the return on what you get from them. I reference this as I have one customer in Michigan who has replaced his SHO kit calipers twice in 12 years as it's his daily driver and fun car. He once said it's cheaper than the rubber he goes through and a helluva lot easier than bothering to try and rebuild them for what they cost new.
But...if boots are your thing we do have the DP caliper as well.
Keep in mind that few can claim to run in a much dirtier enviroment with dust and gravel than I do. None of mine are booted. I did replace both rears due to excessive rock damage to the body this year. After five years. Can't very well show up at Pikes Peak with crappy looking parts you know...not as a dealer!
E is standard in the WW factory 'race' kits. I've supplied it to a number of guys for modest track use on other cars such as SRT4 and Lightning with good results. For the most hard core and hard braking tracks they may break down a bit at the upper temp range in which case pads such as H really shine.
The higher Cf pads such as those in the upper chart will work better for open track use and you'd never go back...but...they can be hell on rotors at cold temps, dust heavily if not run hot enough and are more costly. Being a higher Cf they simply bite better with less pedal effort. You get very high rotor torque with lower operating pressures. None of them should be considered a good street pad. Yet I have some who do that too.
I understand your point about dusting heavily... What do you mean when you say "hell on rotors at cold temps" ?
Originally Posted by matma92ser
Pardon my ignorance, but if they bite better with less pedal effort, and performs this way across low and high temperatures as shown on your chart, then wouldn't it perform well on the street?
They certainly will bite better on the street as well. At the expense of pad wear, rotor wear, dust and noise.
As for 'hell on rotors' how about a replacement set in maybe couple of weekends of spirited driving? Had one customer run J pads on his truck for a lead-folllow drivers school of some type. After the weekend the gas slots were completely gone and his white truck covered in metal dust.
Run on proper 800* rotors this does not happen, but at colder temps it's pure metal on metal wear.
The Wilwood box kits come with Q pads in the Street kits and E pads in the race kits. Both are a reasonable application.
The larger 13" TCE kits offer you a wide range of selection and I'd probably do the BP10 pads in them as an 'all around' pad.
BP10 is not in stock yet for the DynaPro caliper. You might opt for the E with the race kit and request a set of Q for your daily use.
Tires, Wheels & Brakes
10-01-2015 02:22 PM
10-01-2015 12:18 PM
10-01-2015 10:38 AM
10-01-2015 10:17 AM
