Fix-a-Flat
I used it
And frankly, I'd rather live with run flats vs ever use it again.
As far as I'm concerned once put in a tire the tire is shot. You'll get home OK but I doubt you'll ever get the wheel/tire to balance again. While the stuff was in the wheel the balance was so out of whack I was afraid to go over 50. Would it ever get completely cleaned out? I dumped the tire and cleaned the wheel.
I may move to non-runflats in the future, and carry this stuff. But will expect to replace any tire I ever am forced to apply it to.
Originally Posted by YuccaPatrol
Just make sure to tell the tire guys that the tire has the gunk in it.
Tire guys generally hate having to clean it out. . . . .
And whenever the tires are off the rims, you might as well get new valves since they only cost a couple bucks. . . .
on
Under the right conditions the stuff does work. I wouldn't use it unless I really had to. It is doesn't repair the tire. It, hopefully, allows the tire to hold air for the trip to a tire store. That's all. If you don't want to throw the tire away it needs to be cleaned and patched asap. It's a messy job. I cleaned the wheel myself. The tech told me never to forget to have a new vavlestem installed. It did save me the expense of a new tire but, what a pain in the a$$.
I carry FAF, but I prefer towing insurance and a cell phone.
$0.02 worth
$0.02 worth
For the MCS non-runflat users, you might consider this: http://www.ultraseal.com
Seals non-sidewall punctures up to 1/4", approved by US Postal Service for fleet use. Does NOT impede tire/wheel balance or create a mess inside the wheel.
Well known in the UK, just getting started here.
Alex
What about this?
http://new.minimania.com/web/SUBTYPE..._Inventory.cfm
Also, my BMW motorcycle had an excellent tire puncture kit of the plunger/plug type that worked VERY well.
Originally Posted by Verruckt
