White Wheels! yes/no/pics
#26
When I bought my Cooper indy blue and white, I ordered it with silver "holie" wheels. This spring, my friend was selling a set of white holies for dirt cheap, so I bought them. I thought they would look a little "femmy" (think New Beetle with Flower wheels ) but that's not the case at all. I think the car looks great with the white wheels. I don't have any pics of it with the white wheels on.
I do have some with my gunmetal SSR Comps, and the silver holies, though
#27
#29
#33
Wow, those look sweet, Mike! Are you considering springs yet? I just had the HSport springs put on along with the RSpeed 22mm rear sway set on the middle setting and the setup has exceeded my expectations and more. The ride is SO much smoother when you're just driving, and the balance is PERFECT in aggressive cornering. And it NEVER feels like the back would come around (yet) with the driving I've done so far. PLUS, the drop is JUST RIGHT. I've seen the M7s and the H&Rs but they're just a bit too much. This drops the rear to a hair below the wheel arch and the front looks, well, great. I'm completely satisfied with both mods. Highly recommended.
As for those tz-10s, I was looking at those in either 17 or 18s, or the Branzach bz-12s in either 17 or 18s, in white. NOW, I can see EXACTLY what my car will look like with them. THANKS MIKE!
If anyone else would like to show off their white wheeled beauties, well let's have it!
Thanks everyone.:smile:
-Steve
-Steve
#34
#35
#36
Originally Posted by foldinghalo
@ Electron_Mike or anyone else with TZ-10s
I've been considering the same wheels... they just look so "right" for the car. Did you have to get replacement lug bolts or convert to lug nuts for the wheels or do the stock bolts work/look just fine?
Thanks :smile:
Thanks :smile:
#38
Thanks for the reply. Sorry for all the following questions but... Did you weigh them before mounting? I seem to recall they're about 17lbs for the 17". Which lug set did you go with? The one from Pilo Racing? I forgot to ask if you needed spacers and did the wheels include hubcentric rings? If so were they plastic or aluminum? I think that should just about do it!
I see WheelMax has them backordered again...
I didn't get the chance to weigh them because I was at school when they got mounted. I got the lugs from a local shop, which appeared to be of good quality. No spacers are required, and while the wheels do not include hub-centric rings, they come with a little paper telling you where you can get a set of plastic ones for 40 bucks. (www.justforwheels.com) I went with aluminum ones from www.discounttiredirect.com for 15 dollars As for the size, Exel wheels have a centerbore diameter of 73.1 mm, and a Mini's hub is 56.1 mm.
#43
#44
Well, I'm still split on wheels... I would like to do white, and the tz-10 in 17" are on backorder from www.wheelmax.com, but my new front runner is the Branzach BZ-12-
I tried to get weights and details from the maufacturer, and they told me the BZ-12 is discontinued! Wheelmax has some left in stock and I think I need to move quickly. What does everyone think? MINI enough?
#45
#48
last time i went to a store that sell these wheels.... I asked for white wheels ...and the sales person said that white wheels are not trendy anymore....
But anyways... it might be out dated for the other cars...but to mini, I think white wheels look great....especially yours wif white roof...
#49
ebowling
90
08-04-2019 09:15 AM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
01-02-2018 07:26 PM
12-23-2015 10:36 AM
Navigation & Audio help identifying a couple wires
yashmack
08-15-2015 03:11 PM
O4mcs
08-06-2015 05:42 AM
