Ecsta V700 availability
Originally Posted by astra
When does Tire Rack expect to have the Kumho Ecsta V700 in 205-45-16??
Looking for a set of heat treated and shaved for a track day in SoCal June 17..
andy
andy
Best bet is always to call Alex@tirerack.com and tell him what you want and if he can't get the right tire he can give you best estimate of time needed or possible other tires that might work for you.
In 205/45-16 (outer tire diameter 23") there are-
Hoosiers
A3S04 $205 each low stock
A3S05 $190 each In stock
R3S04 $190 each In stock
In 225/50-16 Shaved to 4/32" (outer tire diameter 24.5")
Kumho Victoracer $175 each In stock special order heat cycled/shaved
Another option are Toyo RA-1 tires from edgeracing.com
http://www.toyo.com/tires/tire_lines...s_car/ra1.html
Both have outer tire diameter of 24.8" at 8/32" tread- shave to 4/32"
205/55-16 $162 each fits rims 5.5 to 7.5" wide 23 pounds
225/50-16 $165 each fits rims 6 to 8" wide 23 pounds
In stock!
Something to consider for those on a budget
Hankook Ventus Rs2 Z212 (more of an autocross street tire)
205/45-16 for $81 each 19 pounds each
205/55-16 for $79 each
215/45-16 for $85 each 20.5 pounds each
225/50-16 for $83 each
225/45-16 for $88 each 21.5 pounds each
In stock.
Falken Azenis (Sport) Rt215 $100 each 22.8 pounds (autocross tire)
In stock.
NorthWestEuro
10-22-2016 07:57 AM
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
