Ultimate Fix-O-Flat Solution.. From Continental
I have the 12 V air pump with tire sealant available from Continental!
$75 for the kit!
This is the same Kit OE spec on the 05 Ford GT.
This kit features a water solubile tire sealant.
The recharge kit is $25, and includes a new air hose, and a new can of sealant. - this makes your kit good a new.
This kit is not yet on my cite, but I will post when its available.
Call me to order
Alex
$75 for the kit!
Call me to order
Alex
I found more info: http://www.signonsandiego.com/uniont...lz1d6ford.html
http://www.conti-online.com/generato...ortkit_en.html
Too bad it doesn't work with sidewall holes too.
on
How does this compare to tire slime?
www.slime.com
Once installed into the tire, Slime remains liquid, evenly coating the inside. When a puncture occurs, the escaping air forces Slime into the hole where it creates a long-lasting, flexible plug. It's non-flammable, non-toxic and water soluble.
[QUOTE=paulsminis]It sounds to me that the improvement over the slime treatment is that the stuff is water soluable, and that after using this stuff, one could actually probably clean out the tire, repair and reuse it.
That's what I would hope; that the tire can be patched and reused with no balance, etc. issues.
I love my runflats, but I guess I am a fickle guy!
regards,
Red
regards,
Red
Originally Posted by webstrands
Does this leave a bunch of goo inside the tire? When you get to a tire shop and they pull the tire off, what do they find? Is this a temporary fix to extend the run flat distance or is it a permanent patch?
Alex
PelicanParts.com
05-21-2023 04:51 AM
PelicanParts.com
Accessory Products
10-01-2015 01:23 PM
