Anybody using a Honda Civic doughnut spare tire/wheel?
It's more work, but you can use that spare. If you get a flat in the front wheel, rotate the rear wheel to the front, then put the compact spare in the rear.
A coworker of mine has an S2K, and he was telling me that is what he would have to do with his factory spare.
Just get one of those exaust powered bag jacks to lift both sides of the car, and a DeWalt 18v cordless impact gun, and you'll be done in no time.
Dave.
Dave.
i don't have a civic spare, but i did get a spare off a late 90's vw jetta. 4x100, 125/80/15 size(closer to stock than mini spare). the only bad thing is the centerbore is 57.1mm instead of 56.1mm. I doubt its enough of a difference to cause any safety issue especially since it's just for temporary low speed use.
So Alex. What's the lightest and cheapest way to go?
So Alex. What's the lightest and cheapest way to go? I've got the non-runflats. Don't want to wait for Mini roadside assistance in the middle of the night somewhere and don't trust fix-a-flat and an air compressor. Isn't there some little cost-effective doughnut type solution that can fit behind the passenger seat so as not to become a missle in a panic stop?
Mini holies work but they take up more space than a doughnut.
Thanks for your interest, but Mini holies work, but they take up more space than a doughnut. I've heard of people putting spares in a bag behind the passenger seat, but I was thinking of something thinner in case I carry a person with long legs.
Originally Posted by Alex@tirerack
Your just running on your lug bolts, the entire weight and transitional forces from your mini.
Alex
Alex
--Jeff--
Originally Posted by thebaron862
The lugs also have to be able to handle a massive amount of force since anytime you stop the car, a good portion of the rotational force would be put on the lugs themselves.
Plastic hub rings are totaly acceptable (or small metal for that matter), the only time you'd damage them is upon install, or on abusive track ( high brake heat conditions). They fit tightly so there is no play when torqued on.
Alex
[edit] I believe Alex is agreeing with this point, although he's being awfully unclear about it.
There are plenty of cars on the market that do not come with hubcentric wheels and they somehow manage to drive 100K miles without the wheels falling off.
If the lugs only purpose was to keep the wheel secured to the surface of the hub, then what would stop the hub from spinning inside the wheel when you step on the gas or what would stop the hub/brake from locking while the wheel spins on the hub when hitting the brakes. Most of the force would be put against the lugs since the wheel can spin freely when sitting on the hub w/ no lugs on(even when using the stock rims which have the same centerbore as the hub).
In reality, I imagine the picture isn't so clear - there is probably some combination of lateral force on the lugs and friction between the wheel and hub that keep the hub and wheel turning together.
Actually, since the mini uses wheel bolts and the Honda uses nuts, there may be a slight problem.
The Mini's bolts are 17mm, so Mini puts a very small bore in the wheel. The Honda will use, I don't know, 19mm or 21mm bolts. These bolts will more than likely fit into the bore on the wheel, BUT getting a 19mm-21mm socket in there too might be a bit of a squeeze.
It should be easy enough to check. Grab your 19mm or 21mm socket, and see if it fits in there.
10-01-2015 01:34 PM
10-01-2015 01:34 PM
10-01-2015 01:28 PM
10-01-2015 01:28 PM
10-01-2015 01:13 PM
