17" runflats swap to 17" non- runflats
I have a 2004 mini cooper S, Chile Pepper Red, White Roof. Love the car but the run-flat tires I have already replaced two for inspection in Dec.2004 ( to a tune of $650.00 dollars from the dealer!) and now need to replace all four with non - runflatsOne place I asked told me " that car is an unstable box!" " And if it came with run-flats then it has to stay with run-flats!' " And if they changed them to nonrun - flats that I would kill myself and they would be held liable!" " No!" The next place told me they could order them but when I asked if they would be able to change them they said that they never did this but woud ask their " Best " man if he could then went through the motions of doing so. The next place said they could get me tires but had never changed them and was told that you needed a heavy duty machine to break the heavy side walls, but were willing to try. I can't believe this is such a problem! I live in the Pittsburgh Pa. area so I'll need a all season performance tire in 205/45 - 17. Can anyone help?
Don't take your car to a tire shop which doesn't have the proper equipment and trained personel to deal with runflat tires ... you'll end up with damaged wheels if you do.
The Tire Rack can recommend an installer ...
http://www.tirerack.com/a.jsp?a=EZ3&url=/installer/index.jsp
205/45-17 all-season tire choices:
Avon Tech M550 A/S (Ultra High Performance)
Toyo Proxes 4 (Ultra High Performance)
Falken Ziex ZE-512 (High Performance)
They are MORONS, period!
Try Discount tires. They usually have the latest equipment and do this all the time. I took my 99 vette there with the GY run-flats and they installed non-run flat Michelin pilots with no issues. It even had the pressure sensors in the valves and there wre no problems...
I plan on doing this also to my MCS. You will love the difference in ride, handling and performnace!
Thank you all!
Thank you all for the replys. No one said what tires would be suited for Pa. winters. Something all - season but also performace rated and something that will get more than 10-15 thousand miles, unlike the run-flats. Will it handle the same? I see some said the ride was better with non-runflats.
I recently (2 weeks ago) switched the runflats out for Kumho Ecsta ASX non-runflats. I then turned around and drove about 2000 miles on a road trip.
I haven't tried them in bad weather yet, but expect them to be better than the performance runflats I had. I am very pleased with the improved ride quality, though. A great deal smoother, and a little bit quieter.
Edit to add: These new ones are all-season, non-runflat and slightly larger (215 instead of 205).
A few weeks ago, I went to my local Discount Tire and asked them for a set of Toyo Proxes-4 (aka p4) 205/45/17" for my '03 MCS. They are all-season performance non-run flats and are a HUGE improvement over the stock Dunlop run-flats in terms of ride noise and road feel.
What I found is almost any reputable tire dealer can get you almost any tire. The bigger chain tire shops (Discount Tire, Sears, etc.) should have no problem removing run-flats.
http://toyo.com/tires/tire_lines/spo.../proxes_4.html
scottselk
07-20-2019 06:43 AM
semibreve42
10-02-2015 09:06 AM
