need quick help? Will these rub?
You start cutting away plastic ...
It's not a big deal to do. Best thing to do is drive around a while with the new wheels/tires and then take them off and see where the rubbing will be. Most likely only in the rears, but with 40 offset it may happen in fronts also.
I'm very low now and am running 17x7.5-45 with 235-40s. Using a 5mm spacer in the fronts.
Originally Posted by Boludo
I've got 05 mcs and I am looking at some 17 X 7.5 wheels with 40 offset. I will be putting on the M7 springs which will lower it about 1.3", Will I have any rubbing issues? Thanks for the help.
Im running +42 offset 16x7.5 wheels with 205/50/16's GS-D3's.
considering the bulge on 50 series tires and the bold shoulders of
the GS-D3's I use, if you get a 215/40/17 size with slim shoulders,
(which Im sure minihune will share you with his list of wisdom of
narrow shouldered tires...well, any tires for that matter... ) you
might be able to get it to fit without dremeling.
but even if you do need to dremel, it's not hard to do, from what
I read. maybe 15min with a dremel and you're done.
freeman727
12-10-2017 04:00 AM
wildwestrider
11
01-29-2016 05:06 PM
