Tire dumb person with a question
So i am guessing from the semi-smart/funny replies... that this isn't normal... I am not new with spirited driving in higher performance cars. Its just that I feel like something is wrong since they don't make a sound I just get to a point and boom... my rear end is sliding without any real warning
-Josh
-Josh
The front end doesn't slide? Are you braking when the rear gets loose? Or does it come loose under power? I'm no expert with front drive, but I have had a lot of experience with rear engine, rear drive. My guess is if you are losing the rearend and have plenty of grip in the front, you could gas it and pull the rear around behind you.
Steve
Steve
The sliding is the least of my concern...its the no warning sliding... does the no noise coming from tires mean something wrong or something that I will have to get use to? I just don't want something wrong with my tires and continue to drive spirited and have something majorly wrong happen to them or the car.
-Josh
-Josh
Well, I don't know how you drive or if those are the stock runflats, but there is usually some indication (feel) that they are about to go. Or if you run on the hairy edge all the time, then anything like a little sand, oil or water on the road is going to get you. City streets are not perfectly clean surfaces so you have to watch out.
Steve
Steve
Steve
Steve
I drive with ASC off all the time (that should tell you something)... and even the tires are stock. If tire won't give me any sound feedback I will have to adjust; if it sounds like something is wrong with them... PLEASE let me know.
-Josh
Josh,
I hope you are not driving on public highways when you are spinning your wheels thru 1st and 2nd gears and getting sideways.
Is this your first front wheel drive preformance car? When you say the rear end slides without warning just what are you doing when this happens? Are you accelerating thru a corner or are you coasting or on the brakes or a sudden lifting off the gas when it happens?
If you are lifting, you are the cause of the slide. DON'T DO THAT!
If you are on the brakes in a corner, you are the cause. DON'T DO THAT!
Some tire are more communicative than others. If you are waiting for audible signals from the tires I think you need to make an adjustment and learn to feel the car and what it is telling you thru the steering wheel and the drivers seat about what is happening. The signals are there, you just may be looking in the wrong spots for them.
Have you checked the air pressure in the tires? With run-flats this needs to be done with a pressure gauge at least once a month. You can not see underinflation in the sidewalls as you can with conventional tires. Make sure the pressure is set to factory specs.
Better yet, enroll yourself in a driving school at the nearest local track or find an auto-X club in the area and do you "spirited driving" someplace safe for the rest of the population.
Originally Posted by Bilbo-Baggins
Josh,
-Josh
Mini'mon
08-16-2015 04:15 PM
minipopkart
08-13-2015 05:22 AM
