Anyone Else w/Kosei K1 TS?
Originally Posted by jabrowntx
Just curious -- Did you have to have hub rings installed when you switched to the K1 TS? I have some vibration at and after 50 MPH. I've had the alignment checked and it was ok. So at this point it's either balance or tire issue I believe. Thoughts?
Originally Posted by dkstone
I have two sets that i bought from Tirerack, they came with metal hub centric rings no issues at all
I got mine from Tirerack, but through a local Discount Tire store so I could get their road hazard warranty. Were the hub rings "pre-installed" on the wheel or is that something you have to put on the axle before putting on the wheel?
They were pre-installed on the wheels
Thanks for the reply!
