X-Lite question
Old 09-11-2005 | 03:02 PM
lcubed's Avatar
lcubed
X-Lite question
okay, here's my stupid question of the day:
i've got a brand new 05 MCS w/the stock 16" X-Lite wheels.
where's the tool required to remove the hub cap covers??
or if no tool is secreted in the vehicle, how do i remove
the covers without beating up the white paint??
(i looked in the little tool bag w/ the jack and under the floor mat
by the battery compartment, but no tool)
Old 09-11-2005 | 03:53 PM
moreorless's Avatar
moreorless
There should be a little hookydoo bent wire device in the pouch with your tow hook and screw driver. If not, then see your dealer for a complete kit.
:smile:
...Les
Old 09-11-2005 | 06:16 PM
Tarzan's Avatar
Tarzan
Yes, the "doo-hickey" is the tool. I refer to it as the handgrenade pin. It's in a syrofoam box jammed down beside the battery under the boot carpet. Your tow hook, screwdriver, and manual sunroof crank is also there. Cleverly, if you get the locking lug bolts from the dealership, the key is designed to fit in the one open spot of that box.
Old 09-11-2005 | 07:02 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Like this? minus the explosive parts!- :impatient
A stiff bent wire would also work.
Of note, when autocrossing or driving on the track please remove that plastic hubcap cover.
Old 09-11-2005 | 08:37 PM
lcubed's Avatar
lcubed
thanks all. i had assumed that styrofoam box was a piece of padding for the battery.
is the wrench for the sunroof i don't have?? :smile:
Old 09-12-2005 | 05:39 PM
SteveS's Avatar
SteveS
My tool kit (003 MCS) was in little compartment next to left taillight. A velcro strap holds the kit in and the little wire puller has ring to put your finger in and a right angle prong which goes into the holes around the perimeter of the wheel center piece.
Grizld700
12-30-2015 11:47 AM
donniedarko
10-21-2015 02:15 PM
twriter
10-02-2015 04:14 PM
Carwash
09-15-2015 03:02 AM
marc0011
09-10-2015 11:04 PM
Quick Reply: X-Lite question
