S break cal & Holey 15 wheel ?
Old 09-16-2005 | 10:45 AM
doombuggy's Avatar
doombuggy
I put a set of Holeys on my S yesterday and I noticed the front break caliper is really close to the inside rim of the Holey wheel.
I assume as long as its not touching this is ok?
db
Old 09-16-2005 | 11:11 AM
polmear's Avatar
polmear
no problems!
stock calipers are designed to a 'nominal' clearance to the minimum sized wheel for the vehicle, most OEM's use a very small nominal clearance ~5mm, with the many variations that can happen in the manufacturing processes, the caliper can end up very close to the wheel. The only time you may have a concern, is if you get the brakes really hot, thermal expansion could cause problems if there isn't ~3mm of clearance when the brakes are cold.
Old 09-16-2005 | 11:30 AM
Wenzor's Avatar
Wenzor
i run holeys on my S in the wintertime, no problems. If your calipers themally expanded so much as to hit the rim, your car is melting....
Old 09-16-2005 | 06:31 PM
bodinski's Avatar
bodinski
Coopers & Esses use the very same calipers, anyways.
Old 09-19-2005 | 09:00 AM
doombuggy's Avatar
doombuggy
just making sure, cooooool!
some S's have bigger breaks though right?
db
Old 09-19-2005 | 09:51 AM
sprp85's Avatar
sprp85
db
Nope. Unless a person has installed a BBK..
ebowling
90
08-04-2019 10:15 AM
MORENOJM
09-20-2016 09:13 PM
womble
Classic Mini Talk
08-24-2015 01:52 PM
1Marine
08-24-2015 06:43 AM
petegtsv10
R57 :: Cabrio Talk (2009+)
08-23-2015 08:58 PM
Quick Reply: S break cal & Holey 15 wheel ?
