Rear Suspension: Scalloped Tires?
Old 09-29-2005, 10:58 AM
Alex@tirerack's Avatar
Alex@tirerack
Alex@tirerack is offline
Originally Posted by andy@ross-tech.com
"Alex",
What are your thoughts in cross-rotating tires on the MINI (as long as said tires are not directional)? Do you believe, as ingsoc asserted, that:
While old bias plied tires (the grandfather's of today modern tires) had driectional memory. Today's modern radials (banded at 90 degrees) combined with more sophisticated construction components ( less complete nylon construction)
When non directional favor well and wear most evenly when rotating side to side. Directionals must be dismounted to do this - and still maintain the correct rolling direction.
In simple form - if able to rotate side to side, do it.
Alex
  #27
Old 09-30-2005, 02:25 PM
The Italian Job's Avatar
The Italian Job
The Italian Job is offline
Just thought I'd ask one more time. Does anyone know the "magic" alignment settings that eliminate the rear tire scallop?
  #28
Old 09-30-2005, 08:24 PM
J0kER's Avatar
J0kER
J0kER is offline
well i found this for ya cuz on mine i have rear kit set up so not stock. mine is at -2.0 cant remember if i left it at that though, but here it goes check this out d0od https://www.northamericanmotoring.co...ewpost&t=51888
07-16-2020 12:54 PM
W0TM8
12-19-2019 07:50 AM
kazyn
10-25-2019 02:34 PM
Toolman
01-20-2016 06:50 AM
pre shrunk
08-18-2015 11:09 AM
Quick Reply: Rear Suspension: Scalloped Tires?
