What tire size on 16" wheels for street/AutoX
I am probably going to pick up some 16 x 7 Rota Grids w/40mm offset.
On the tire side, if I am going to get something like the Goodyear F1's, what size should I go for? I have the H-Sport springs, and will be doing spirited street driving and a few track days (hence the 16" wheels...)
Thanks!
Robin.
Thanks!
Robin.
Talk to alex@tirerack.com
For autocrossing:
215/40-16 for the Goodyear Eagle F1 GS-D3 $131 each
No rubbing!
205/45-16 will also work $128 each.
http://www.tirerack.com/tires/Sizes....=14WR6F1GSD3XL
For autocrossing:
No rubbing!
I have 215/40/16 Proxes T1R's on the 16x7 45 Rota's and they worked great Sunday at Road Atlanta. Very happy with the combination. They fit over WillWood BBK with no spacers and no hub rings. I dropped from 53# to 35# per corner in weight, picked up 7% gearing improvments, and it actul;y rides better than the runflats also. Good for about 1.5 sec/lap at Road Atlanta.
Wes
Wes
The Hankook Ventus RS2 Z212 is a relatively popular tire in the Street Touring classes (in other words, it should be a fast street/autocross tire), and is available in 205/50/16 and 215/45/16.
The Falken Azenis is probably the fastest "Street Touring" tire, but it doesn't appear to be available in a Mini-friendly 16" size They do have a 205/40/16, but I think it'd be way on the short side for street driving.
Thanks!
Robin.
Thanks!
Robin.
I'm running Rota Slipstreams with the same size and offset.
I'll second Wesport on the T1Rs. Once they get broken in and worn down a little, they are an excellent compromise for the street and track.
The Azenis is suppose to become available soon in a 215/45/16 but that's still a little short for most people who aren't real serious about autocrossing. I'd stay away from the F1's or any of the "Rain Tires" if you think you will be autocrossing on them more than just a couple of times unless you just want to see how quickly you can chew up some really good street tires. I think the 205/50/16's Z212's are the right thing for you!
Mini'mon
08-16-2015 04:15 PM
Rennfahrer555
08-13-2015 09:07 AM
