Hand brake service notice.
Has anyone had a problem with the rear brake pads rubbing? The brake warning light came on and the dealer said that there was a service notice on the rear brakes. This was due to the routing of the hand brake cable which caused the pads to engage even when the handle was released.
The thing is that the MINI was in for service just two weeks before and the brakes were checked. They said that the pad wear was in spec and everything was fine. Some how, according to the dealer, the cable kinked or dragged and the pads rubbed and wore the rest of the way out in just two weeks with out much driving. The MINI is a 2003 with 28,000 miles.
I don't know when this service notice was issued. When we first called in they told us it might just be the warning light malfunctioning. We were told this before when the engine light came on and didn't take the MINI in right away as we were told it probably only needed a reset of the computer. Then just a couple of days later a valve spring broke. I have learned to insist that they check in to the cause as soon as possible.
gmonde
09-08-2015 06:37 AM
JPMontes3
08-23-2015 01:26 AM
