Team Dynamics Pro Race 1
Originally Posted by Alex@tirerack
205/40 is a tad short. 215/40 is the shortest I'd go - with 36 psi behind it.
Alex
Alex
Only if you care about staying with the stock diameter. Some people would consider a smaller diameter a good thing - myself being one of them.
From a rubbing standpoint, a 205 is less likely to rub than a 215. A 40 profile is less likely to rub than a 45 (given the same suspension settings).
You should be fine regardless though.
To get the best handling out of a the tire, I would not go wider then a 205 on a 7" rim . 40 will ride quite a bit firmer then 45. Both options, 205-40, 215-45 should not rub at stock height. Always a possibility that a 215 will rub when lowered.
I'd stay away from team dynamics myself as they are impossible to communicate with.
patsum
26
05-29-2021 06:29 PM
F55/F56 JCW Pro Coilovers... on a Justa
MidnightF56
09-10-2015 01:04 PM
