Questions about 15" for an MINI S
I have a set rota circuit 8's 15 x 6.5. Tires are 195/50/15 toyo t1-s fitted on my MCS... My questions is... will the tires be too narrow?? Do I need 205? or even 215?? It will mostly for street use and might be some autox .. any info would be great... thx..
#edit.. also I have lowering springs on the car..
Those are REALLY short sidewalls.
I've autocrossed on my 195/55/15 Yokohama AVS ES100's a few times, and they really don't have enough grip... But then, I normally autocross on 215/40/16 Kumho V710's, so I'm used to fairly sticky tires.
The Toyo's should be a little bit grippier than my Yoko's, but I think you'll pretty quickly find that you'll want something stickier and wider.
However, if you're new to autocross, just run 'em until they're gone. They're fine to learn on.
Originally Posted by Alex@tirerack
195/50 is short in load and diameter
225/45 works well for Auto X applications and has load!
alex
alex
I've got 205/50 SO3s on there now and although a little lower than stock it's nice
Originally Posted by BRGminiS
umm... will my wheels fit a 225 tires?? I'm a total noob when it comes to wheels... oh.. the wheels offset is +38
However, I'd say that if you're interested in autocross, I don't know of any truly good-for-autocross 225/?/15 street tires? I'd just go with the Falken Azenis is 205/50/15. It might not be 225 wide, but the sticky compound will make up for the narrower tread width.
If you're going to go with a dedicated autocross tire, there are a couple more 15 inch options.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 02:35 AM
andrewjg1994
01-29-2021 08:45 PM
jrezzo
08-09-2015 11:32 PM
