Where to buy 4mm spacers?
why not jus go w/5mm...not that much difference!
Originally Posted by Strom
Actually, I already have 10mm hubcentric spacers to fit my Stoptechs. I really only need 4mm spacers to clear the brake kit, but they wouldn't be hubcentric. From what I've heard, spacers that are 5mm and under still allow some contact between the wheel and the hub, minimizing problems.
Originally Posted by schooner2
I had custom 3/16 thick wheel spacers with 56.13 to 73 mm hub centric rings built into one solid piece, they are very nice and they were only $42.00 a piece!!
Spacers, especially when they go out too far, stress wheel bearings. I've read a fair amount on this recently, including some PMs...
I have a +42 offset wheel, and I recall some reasoning to where the addition of spacers is fine so long as an effective offset of +35 is not surpased. So, with that logic, I'd be able to go out 7mm max. I'm contemplating 5 or 6 up front, and 3 or 4 in the rear...
EDIT/ADD - If I understood correctly, our stock MINI wheels range in offset from +35 to +52. Spacing-out to +35 would be "safe" in that MINI thought it was ok...
where did u see info on spacers????
great!
( talked w/him last week, i believe) hes checkin' on sum prices for me
so mayb we can get a NiCE price quote....it depends on how many and how thick the spacers u need....
im going w/sum thin' front & back!
Originally Posted by TonyB
schooner2, I like that idea, and the price sounds right also. My current hubcentric rings are plastic, and I want to change that; and I wouldn't mind a slight spacer as well, all in one. Please share where and how you got this done! Thanks.
joker, do a search here, and on MINI2 to get plenty of discussion, and opinions on spacers...
I want a wider stance, not so much for appearance or bling, but for better stability in sweepers. I've heard that these help in that regard, namely by going wider in the front, as compared to the back.
I'm definitely interested in spacers that also include the hubcentric rings, so please do share. The quality of material (light and strong) and craftsmanship are of high importance for something like this of course. Such details would be nice to know... Thanks.
=0)
yea im currently talkin' to a few peeps that can make these so not yet sure on what type of material they will be using but 6061 should be jus FiNE, NO!?
thx, on the info from 'MINI2'...they do have a lot going on over there dont know why i dont hang out over there more
im not goin' to use these on the track so jus fo' l00ks here...will u be using a set up like this on the track?
is it safe?
& im assumin' u will be switchin' to a beffier set of lugz!?!?!
is it safe?
The John Cooper Challenge race cars use these in the UK. (7mm and 9mm)
I would suggest converting to stud if you are going to use a spacer. Not that you have to, but at least you have visual indications of how many threads are left.
My first choice will always be not to use them but if you have fitment or brake clearance issues, you should be ok.
With a quality spacer, you should not have any problems on the track as long as the offset is within specs.
JP
JP
Reading my mind J! Turner shipped 16 75mm studs to me today . That, along with some open nuts, eye-balling the threads, and having easy access to the allen are achieved.
I need some spacers now, and I really dig the idea mentioned here. schooner2 and joker, as you learn more, please share. Thanks.
I already have a stud kit on my car. Mostly, I am interested in smaller spacers as I just have too much width on the front right now. The +37mm offset Superleggeras + 10mm spacers makes an overall offset of +27mm. My car is exhibiting a LOT more torque steer since I have had this setup installed. Thus, I would like 4mm spacers.
Joker, keep us informed - I would be very interested!
I need wheel spacers to clear my wilwood brakes and i didnt like the idea of a wheel spacer and a seperate hub ring, by having a wheel space it didnt leave much room for the hub ring to ingage the hub stud so I had it built as one piece, I fell its much safer and i dont feel any diffrence in how the car handles or the wheel shake so I am very happy with my spacer, I just found a shop that had a cnc machine and sent them a drawing of what I wanted and he told me how much, i thought it was very resonably price for just two spacer. Doug at Whelen machine was going to make them for me for 65 a piece but became so busy he couldnt so I found a local shop to do it!! if anyone is interested i would be happy to give you the guy name and number for quotes!! just pm me!! : )
OutMotoring
09-08-2015 07:27 AM
