problem breaking wheels loose
I am new to the forum. I am trying to rotate the wheels on my 2003 Cooper S. It appears that there is rust between the wheel and center hub which is making it difficult to pull the wheel off.
Is there a tool that helps with this, or is it okay to thump the wheel from the inside with my foot to break it loose.
I do not want to damage anything, such as wheel bearings.
Thanks!
Thanks!
Originally Posted by MFC
Instead of driving your car around with loose lug nuts, just take a hammer (preferably rubber) and knock the inside of the wheels loose when you have the car jacked up. It's normal for the wheels to be siezed onto the hubs.
Good luck...
Mark
Good luck...
Mark
nooo~ you don't do that to your car. a light tapping with a mallet
might be acceptable but i think his wheels are seized... you don't bang
on your wheels/tires specially not with a hammer.
Good luck...
Mark
Good luck...
Mark
I just rotated my wheels yesterday and had the same problem. I loosened my lugs 1-2 turns on one side, rolled my MINI a little and stomped on the brakes. Read that on one of the threads here. I still had to rock the wheels back and forth to get them off but it worked. Then did the same thing on the other side. Hope it works for you if you use that method.
I had the same problem with the wheels being stuck to rusted axle. I just used a rubber hammer though and after a few tries I got them off. Is it fine to use any grease or lubricant to place in between the wheel and axle for it won't happen again or further corrode? Wouldn't that fix the problem?
PSIChocolate
08-13-2015 12:46 PM
ki7hy
08-12-2015 07:07 PM
