X Lites with 225 45 16?
It's possible. 225/45-16 is meant for rims 7 ro 8.5" wide but can be forced onto the more narrow X-lyte 16x6.5" rims by a tire specialty shop mechanic.
Try asking Alex@tirerack.com to confirm it will fit.
Is this for a lowered MINI or one with stock suspension?
Other possible tire sizes that will fit stock 16x6.5" rim:
205/50-16
205/55-16
225/50-16
205/50-16
205/55-16
225/50-16
Originally Posted by pyugala
I think it will causes the center section of the tires to balloon a bit hence less contact patch. The widest I would go on 6.5 would be 205/50R16. IMHO
Originally Posted by Minirowski
How about 215 50 16 ?
Fits rims 6-7.5" wide and very close to stock size in tire diameter.
http://www.tirerack.com/a.jsp?a=EZ3&url=/tires/Compare1.jsp&width=215%2F&ratio=50&diameter=16&sta rtIndex=0&search=true&pagelen=20&pagenum=1&pagemar k=1&x=67&y=8&RunFlat=All
on
What pressure are you running with the tires you have on? Just for my info:smile:.
Cheers
Cheers
Originally Posted by Tirewarmer
A Falken RT-215 215/45 R16 fits perfectly on stock wheels. I plan on trying a 225/45 R16 hankook if I can confirm that there are no rubbing issues with that size on stock offset wheels. From the measurements I have taken I don't believe they will rub anywhere at stock height.
Jake
on
Originally Posted by n3nyongmini
Joe-
Did you end up going with the 225's? If so, comments?
If not, whatcha get?
Derek
Derek
I would really like to go with the Hankook due to their price and the slightly taller sidewall that should give a little better(more comfortable) ride on the street while not sacrificing too much performance due to the wider tread width.
shahriar35
09-14-2015 11:53 PM
tylewis
08-18-2015 06:53 AM
