konig rewind? yay or nay?
#151
#153
#155
#156
Originally Posted by ada722
That's a great look lisdexic_driver. Seriously considering the graphites for my DS/B mcs. A couple questions if you don't mind: what size tire did you end up going with? are you at the stock ride height?
thanks
thanks
#158
#159
#161
Originally Posted by DrDiff
It seems to me that the Antracite version might be very good at hiding the brake dust that the factory pads make on the fornt end.
#162
Where can I buy a set of these?
Where did you buy the Konig Rewind 40mm Graphite Wheels and tires. I may want them for my 2006 MCS.
Thanks,
K.Riese
riesek2003@yahoo.com
Thanks,
K.Riese
#166
I'm considering these for my new MC (still scheduled for production). It's coming with delta spokes but they are only 5.5 vs 7. The trade off for me would be I'm in Seattle and the wider tire would decrease traction during the o so common wet road days. Also I'd likely need to sell my deltas to justify buying the Konigs so I couldn't swap them out for fall and winter.
I do have essentially free access to a car lift and would also be putting some aftermarket springs on.
So with ~1" lowering springs and 205/55/15s I should be ok no? Would 195s fit? That might be the sweet spot for me.
#171
quick update for anyone considering alternative brake kits: I've been looking at getting the Wilwood brake kit. It's supposed to fit under 15" wheels, but the spokes on the Rewinds just barely touch the bolts on the face of the caliper. It looks like a small (1/8"?) spacer will provide enough clearance. Way (of Way Motor Works) is going to work with me to see if we can come up with a safe solution for using the Wilwood kit with these wheels. Sounds like a small spacer should be effective provided it doesn't compromise safety on the track.
#172
Originally Posted by agile_moments
I'm thinking about these wheels in 15'' graphite (shown) or silver:
some opinions on these? I searched, didn't come up with much on these so far. I've decided to stick with what I read in the issue of Sport Compact Car about their project Mini and how little wheels look right on a Mini. I've noticed lately that I like how a lot of the smaller wheels look on our cars. Just wanted to get others opinions
#174
Originally Posted by blalor
Good Win Racing has the graphite wheels for $89 each on special.
IMHO These are the best 15" wheels on the market for the Mini Cooper.
I wonder which finish would look good on my Dark silver MCS? Anyone with photoshop skills dare take a stab at this?
#175
