45mm spacers
Old 12-07-2005 | 07:14 PM
koenner1's Avatar
koenner1
How do 45mm spacers affect performance?
Can 45mm spacers all around have any negative effect on the car regarding performance or otherwise? From what I've heard it will actually help the suspension since it creates a wider track, but I just want to verify this before I go and do it to my car.
Old 12-07-2005 | 08:20 PM
kenchan's Avatar
kenchan
damn, that will push the tires out to eternity.
do you mean like a 5mm spacer? or a 10 or 15mm?
Old 12-07-2005 | 08:45 PM
ugly_duckling's Avatar
ugly_duckling
Koenner1 - I do not think spacers will affect performance
Maybe if you had a lowered 1979 Buick with gold wire wheels and a 'Jealousy' placque in the rear window THEN 45 mm might be a good idea - JK
Other wise you might want to think about 3 - 5 mm.
My wheels have 5mm spacer in the back. I used to have them in the front but I took them off because vibration. You can pick them up from Pilo for a great price. My pic below shows what my SSR look like with 3 mm spacers. The original offset is 42 which brings me down to a 39 mm offset.
Click on my sig to see my what they look like.
Old 12-07-2005 | 08:59 PM
koenner1's Avatar
koenner1
yea i guess something like a 10 or 15mm. how would that effect the performance? would i need to correct anything?
Old 12-07-2005 | 09:01 PM
ScuderiaMini's Avatar
ScuderiaMini
Sorry for the hi-jack, but ugly_duckling, are those 16x7s?
Old 12-07-2005 | 09:07 PM
koenner1's Avatar
koenner1
what is offset?
Old 12-07-2005 | 09:19 PM
ugly_duckling
Mind you I am no specialist but OFFSET is the measurement of how much your wheels stick out. For example... if you look at your wheel arches you can see if the wheel is under the arch or flush with it. When it sticks out too much you would have rubbing.
The stock S lites have an offset of 45 if I am not mistaken. If you are planning to get wheels you have definitely keep in mind what offset the wheel comes in.
And the SSR Comp R's are 16x6.5. Hubcentric with no center caps. They were the first production run produced with TireRack just for the Mini.
Old 12-07-2005 | 09:20 PM
ScuderiaMini
thats what I figured, they are not sticking out like 16x7,5s. TY
Old 12-07-2005 | 09:31 PM
ugly_duckling
Scuderia - Ouch! Dont say that out loud. Thats why i went for the spacers. And I still feel my offset is not aggresive enough. -
Here are some great priced spacers for those looking
http://www.piloracing.com/proddetail.php?prod=6mmspacer
http://www.piloracing.com/proddetail.php?prod=3mmspacer
Don't forget to get longer bolts if you go for the 6mm - which is another 50 bucks
Old 12-07-2005 | 09:41 PM
kenchan's Avatar
kenchan
what is offset?
here you go. (link below).
offset will dramatically change handling characteristics
if you do 10mm or more. 5mm is more or less for clearance/cosmetics
imho. i purposefully bought wheels with high offset on my other
car and have a variety of different offset spacers from Kics.
btw, for those looking for spacers, i highly recommend you get ones
with the hubcentric rings (H&R's) unless you can still rest your
wheel on the factory bore.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old 12-07-2005 | 09:43 PM
kenchan's Avatar
kenchan
ugly duckling - your car looks fine.
berky-
16x7.5's with +42 does not stick out btw. it is still tucked under the
fender a little bit. it is very close to flush, but not sticking out...
just the way I like it.
Old 12-07-2005 | 10:19 PM
ScuderiaMini
well, maybe i mistranslated what i thought, you are correct Ken, it is not stickin' out but looks perfect.
ugly_duckling, yours look fine man, nothing wrong.
Old 12-08-2005 | 02:21 AM
Tit's Avatar
Tit
Good thing you put that caveat - because I'm pretty sure they are 50...with most of the other MINI wheels around 48mm...
Old 12-08-2005 | 09:59 AM
kenchan's Avatar
kenchan
yah, i think i read 50mm for the S-Lites too somewhere.
R90s are i think 48mm.
Old 12-08-2005 | 10:13 AM
flyboy2160's Avatar
flyboy2160
despite what is posted in the FAQ on mini2, (and at the tire rack?) and here in many posts, both the czech and hungarian s lites are stamped with a 48mm offset.
Old 12-08-2005 | 10:27 AM
J0kER's Avatar
J0kER
*******if u need them LMK ! "5mm spacers w/hubcentric properties all in one"" *-*****
do u own a ride like this? what chapter? on the "Jealousy" car club
why the vibration?
hmm, ur wheels dont l00k like ur runnin' spacers!! mayb its the pix
Old 12-08-2005 | 11:19 AM
kenchan's Avatar
kenchan
hummmm... those are fake. jk
Old 12-08-2005 | 04:30 PM
ugly_duckling
why the vibration?
Joker - Sorry but I do not own that car. When I was growing up on the east/south side of San Jose Ca they were very popular - followed by the minitrucks and suzuki samurai's. I remember this kid at my high school had an Iroq and he was a part of the 'Jealousy' crew - but he was the biggest dork I ever met.
As for the vibration - I think they must have been by the spacer, because once I removed them the vibration stopped. The spacers were not hubcentric.
YaTuSabe
08-23-2018 12:41 PM
theblackfalcon
10-19-2015 06:22 AM
NickBchillin
10-05-2015 06:11 AM
GAT
10-04-2015 08:27 PM
Zew2888
09-29-2015 09:49 PM
